Technical Library
  • Technical Library
Technical Library
Documents Analog Devices: EVAL-ADXRS646Z Evaluation Board for the ADXRS646 Angular-Rate Sensor (Gyroscope)
  • Author Author: atomar
  • Date Created: 26 Feb 2013 9:16 AM Date Created
  • Last Updated Last Updated: 15 Mar 2013 9:36 AM
  • Views 1744 views
BUY NOWBUY NOWTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Analog Devices EVAL-ADXRS646ZEVAL-ADXRS646Z is a simple evaluation board that allows quick evaluation of the performance of the ADXRS646 ±250°/sec yaw rate gyroscope. No additional external compo-nents are required for operation. The EVAL-ADXRS646Z has a 20-lead, dual in-line (0.3 inch width × 0.1 inch pin spacing) interface that allows easy prototyping of products without BGA soldering.
The ADXRS646ADXRS646 is a very high performance analog-output yaw-rate gyroscope featuring low bias drift of 12°/hr and excellent immunity to vibration and linear acceleration. The small size of the breakout board makes it easy to mount the gyroscope to an existing system without the need for additional hardware and with minimal effect on performance of the system and of the gyroscope.
The ADXRS646ADXRS646 is pin - and package - compatible to the ADXRS62x family and offers a measurement range of ±250°/s, 1 kHz bandwidth, 12°/hr drift with low broadband noise, low g sensitivity of 0.015°/s/g and vibration rectification of 0.0001°/s/g², is ideally suited for high performance navigation and platform stabilization.
The ADXRS646ADXRS646 is a complete angular rate sensor (gyroscope) that uses the Analog Devices, Inc. patented high volume BiMOS surface-micromachining process to make a complete gyro on one chip. An advanced, differential, quad sensor design rejects the influence of linear acceleration and vibration, enabling the ADXRS646 to offer rate sensing in harsh environments where shock and vibration are present.
Key Applications: Industrial applications, Severe Mechanical Environments, Platform stabilization
imageMore Analog Devices Analog Development KitsimageAnalog Devices MCU based Development Kits
Technical Documents
Learning Center
TypeDescription
User GuideADI: User Guide (UG-314) for Evaluating the 250°/Sec, High Stability, Low Noise, Vibration Rejecting Yaw Rate Gyroscope with Analog Output
DatasheetADI: Datasheet for ADXRS646 High Stability, Low Noise Vibration Rejecting Yaw Rate Gyro (Rev A)
DatasheetADI: Datasheet for ADXRS646-EP High Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope (Rev 0)
Product BriefADI: Product Brief for MS-2158 Gyro Mechanical Performance
Design Elements
TypeDescription
CAD ModelADI: CAD Model for ADXRS646BBGZ (BXL File Format)
Back to top
Video
Back to top
Kit Features
Key Features for ADXRS646ADXRS646 are as below:
  • 12°/hr bias stability
  • Z-axis (yaw rate) response
  • 0.01°/√sec angle random walk
  • High vibration rejection over wide frequency
  • Measurement range extendable to a maximum of ±450°/sec
  • 10,000 g powered shock survivability
  • Ratiometric to referenced supply
  • 6 V single-supply operation
  • −40°C to +105°C operation
  • Self-test on digital command
  • Ultrasmall and light (<0.15 cc, <0.5 gram)
  • Temperature sensor output
  • Complete rate gyroscope on a single chip
Back to top
Kit Contents
The Analog Devices EVAL-ADXRS646ZEVAL-ADXRS646Z is supplied with below contents:
  • Evaluation Board
Back to top
  • adxrs646
  • eval-adxrs646z
  • analog_devices
