Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: EB-LM4F120-L35 Stellaris LaunchPad LCD Boosterpack
  • Author Author: atomar
  • Date Created: 1 Feb 2013 4:52 AM Date Created
  • Last Updated Last Updated: 5 Feb 2013 10:11 AM
  • Views 1326 views
Buy NowBuy NowTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The boosterpack include a 3.5 inch QVGA TFT LCD module (P/N: K350QVG-V2-F) and with build in LED backlight driver circuit. The LCD connector also can be interfaced to larger size LCD module from Kentec Display (4.3 inch: K430WQC-V3-FF; 5 inch: K50DWN2-V1-FF; 7 inch: K70DWN2-V1-FF; 9 inch:K90DWN2-V1-FF).
Kentec 3.5” QVGA TFT graphic LCD module with resistive touch screen The EB-LM4F120-L35EB-LM4F120-L35 LCD boosterpack having Outline Dimension (mm) : 80.0 x 69.3 ,AA (mm): 70.08 x 52.56. The EB-LM4F120-L35EB-LM4F120-L35 LCD  boosterpack having Resolution (Dots): 320x240 and it is having 8-bit parallel Interface.
Key Applications: Lower power  applications,Scanners
imageTexas Instruments LaunchPad and BoosterPacksimageTexas Instruments Development Tools
imageOther Texas Instruments Development KitsimageDevelopment Platforms & Kits
Technical Documents
Learning Center
TypeDescription
User GuideTI: User's Guide for Stellaris LaunchPad LCD Boosterpack EB-LM4F120-L35
Back to top
Video
Video 1Video 2
This video is unavailable.
Back to top
Kit Features
Key Features of EB-LM4F120-L35EB-LM4F120-L35:
  • The EB-LM4F120-L35EB-LM4F120-L35 is a LCD boosterpack for the Stellaris LaunchPad
  • The boosterpack include a 3.5 inch QVGA TFT LCD module
  • The EB-LM4F120-L35EB-LM4F120-L35 with build in LED backlight driver circuit
  • The LCD connector also can be interfaced to larger size LCD module from Kentec Display (4.3 inch: K430WQC-V3-FF; 5 inch: K50DWN2-V1-FF; 7 inch: K70DWN2-V1-FF; 9 inch K90DWN2-V1-FF)
  • Kentec 3.5” QVGA TFT graphic LCD module with resistive touch screen
  • The EB-LM4F120-L35 LCD boosterpack having Outline Dimension (mm) : 80.0 x 69.3
  • AA (mm): 70.08 x 52.56
  • The EB-LM4F120-L35EB-LM4F120-L35 LCD  boosterpack having Resolution (Dots): 320x240
  • 8-bit parallel Interface
Key features for Cortex-M4F MCUs:
  • All LM4F variants include the ARM Cortex-M4F core with single-precision floating point at 80 MHz
  • Up to 256 KB single-cycle Flash memory and 32 KB single-cycle SRAM
  • Up to two 12-bit ADC modules and 24 channels of inputs
  • Up to two CAN 2.0 A/B controllers
  • Advanced motion control capability, with up to 16 PWM outputs and two quadrature encoder inputs
  • Generous serial communication, with up to
  • 8 UARTs
  • 6 I2C modules
  • 4 SPI/SSI modules
  • Low power modes including power-saving Hibernate mode
  • 64-LQFP, 100-LQFP, and 144-LQFP packages
Back to top
Kit Contents
The EB-LM4F120-L35EB-LM4F120-L35 is supplied with the below contents
  • QVGA TFT LCD module
Back to top
LM4F120
