Technical Library
  • Technical Library
Technical Library
Documents Analog Devices: ADZS-BRKOUT-EX3 SDP Breakout Board
  • Author Author: atomar
  • Date Created: 26 Mar 2013 12:44 PM Date Created
  • Last Updated Last Updated: 4 Apr 2013 11:27 AM
  • Views 1053 views
BUY NOWBUY NOWTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The ADZS-BRKOUT-EX3ADZS-BRKOUT-EX3 SDP breakout board from Analog Devices, Inc., can be used in conjunction with SDP controller boards and daughter boards designed on the SDP system. The breakout board allows signals travelling between SDP controller boards and compatible daughter boards to be monitored by the insertion of the breakout board between the SDP controller board and the daughter board.
SDP controller boards are used as part of the evaluation system for many Analog Devices components. The SDP breakout board exposes each of the 120 pins of the SDP controller board's connector allowing users to monitor signals between the controlling board and the attached daughter evaluation board or Circuit from the Lab reference circuit board.
The System Demonstration Platform (SDP) is a collection of controller boards, interposer boards, and daughter boards used for easy, low cost evaluation of ADI components and reference circuits.  It is a reusable platform where by a single controller board can be reused in various daughter board evaluation systems. Platform elements can also be used to build, demonstrate, and prototype embedded systems connected to daughter evaluation boards, through the use of interposer and 3rd party boards.
Key Applications: SDP controller boards and daughter boards
imageMore Analog Devices Analog Development KitsimageAnalog Devices MCU based Development Kits
Technical Documents
Learning Center
TypeDescription
User GuideADI: User Guide (UG-282) for ADZS-BRKOUT-EX3 SDP Breakout Board
User Guide
ADI: User Guide for EVAL-SDP-CB1Z
User Guide
ADI: Getting Started with SDP
User ManualADI: User Manual for System Demonstration Platform Breakout Board
Product BriefADI: Product Brief for SDP Facilitates Quick Prototyping and Evaluation
Training VideoADI: Training Video for System Demonstration Platform Simplifies Evaluation
Design Elements
TypeDescription
SchematicsADI: Schematics for SDP Breakout Board
Back to top
Video
Back to top
Kit Features
The Key Features for the SDP breakout board:
  • 4-pin × 120-pin small footprint connectors
  • Hirose FX8-120P-SV1(91),120-pin header
  • Hirose FX8-120S-SV(21), 120-pin receptacle
  • ID EEPROM
  • 240 through-hole probe points
  • An LED connected to the input power line to indicate that power is provided fromo an attached daughter board
Back to top
Kit Contents
The Analog Devices ADZS-BRKOUT-EX3ADZS-BRKOUT-EX3 package contains:
  • ADZS-BRKOUT-EX3 board
Back to top
  • adzs-brkout-ex3
  • analog_devices
