Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: AN01242 - Using the Stellaris Serial Flash Loader (Software Code)
  • Author Author: atomar
  • Date Created: 17 Oct 2011 6:57 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:10 AM
  • Views 416 views
The serial flash loader is a small piece of code that allows programming of the flash without the need for a debugger interface. Two serial interfaces are supported for download to the device, UART and SSI. The serial flash loader uses a packet type interface to provide reliable synchronous communications. Two different UART download utilities are also supplied that can be used to program the flash using the serial flash loader.
2308.Texas_Instruments.Application_Library.zip
  • arm_cortex_m3
  • lm3s
  • serial_flash_loader
  • stellaris
  • texas_instruments
  • lm3s9d96
  • Application Library
