Technical Library
  • Technical Library
Technical Library
Documents ARM: KEIL UTILITY: BINARY to Intel HEX Converter Utility
  • Author Author: atomar
  • Date Created: 13 Jan 2012 3:15 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:17 AM
  • Views 1272 views
This utility program creates an Intel HEX file from a BINARY file. Options for this utility program are listed below:
Syntax: BIN2HEX [/option] binfile [hexfile]
binfile is the binary input file
hexfile is the Intel HEX file to create
option  may be any of the following
  /Ln     Bytes to read from binary file
  /In     Binary file starting offset
  /On     Output file address offset (where HEX data starts)
  /M      Merge data into existing HEX file
  /2      Generate HEX file using ext. segment address records (HEX86)
  /4      Generate HEX file using ext. linear address records (HEX386)
  /Q      Quiet mode (no statistics are displayed)
  /T      Exclude EOF record
  /A      Append to end of existing HEX file
ARM.Code_Snippet.zip
