Technical Library
  • Technical Library
Technical Library
Documents ARM: KEIL UTILITY: Intel HEX to BINARY File Converter Utility
  • Author Author: atomar
  • Date Created: 13 Jan 2012 3:17 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:17 AM
  • Views 2298 views
This utility program creates a BINARY file from an Intel HEX file. You can use BINARY files with most EPROM programmers and you can easily use them for CRC or checksum calculations. Options for this utility program are listed below:
Syntax: HEX2BIN [/option] hexfile [binfile]
hexfile is the Intel HEX input file
binfile is the binary file to create
option  may be any of the following
  /Ln     Binary file length
  /Pn     Pad data for binary file
  /On     Address offset (to add to HEX records)
  /M      Merge data into existing BIN file
  /Q      Quiet mode (no statistics are displayed)
  /X      Don't process ext. segment/linear address records
  /?      This help text
ARM.Code_Snippet_2.zip
