Technical Library
  • Technical Library
Technical Library
Documents ARM: Application Library for Bootloader Code(For Keil C51 Development Tool)
  • Author Author: atomar
  • Date Created: 18 Jan 2012 5:47 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:17 AM
  • Views 418 views
This ZIP file contains some example code the shows you for how to create a program with BOOT code in EPROM from 0000h to 7FFFh and an external program in FLASH from 8000h to 0FFFFh. The bootloader and FLASH programming code is not included in this example project. The project file BOOT.UV2 includes a debugger setup that loads both applications for symbolic testing.
Keil.Application_Library.zip
  • Application Library
