Technical Library
  • Technical Library
Technical Library
Documents element14: Software Examples for LPC4357-EVB (Examples 2)
  • Author Author: vandana
  • Date Created: 17 Jan 2013 3:50 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 6:51 AM
  • Views 1200 views
  • Comments 5 comments
This includes software example code for:
  • GPIO
  • SDRAM
  • I2C - Accelerometer
  • USB
  • LCD
  • Touch Screen
Examples2.zip
    zip fils immernoch defekt?
    e14 Contributor over 13 years ago in reply to e14 Contributor
    Here's a little bit more info on the situation:
    Re: missing documents
    Please provide links to the actual files that can be downloaded
    The code for GPIO has incorrect comments on it which can lead to utter confusion of how the GPIO and pin configuration works! :-
    scu_pinmux(0xE ,7 , MD_PDN, FUNC4);     // P8.1 : USB0_IND1 LED
    As per the Embset schematic, the LED is in fact connected to Pin PE.7, which is GPIO7.7 (GPIO = Function 4 on this pin).
  • jf1452
    jf1452 over 13 years ago
    Element14, please can you check the zip file, it seems to be corrupt. (seemed to be a web browser problem, downloading it a second time gives no issues.
    Many thanks
    Jon
