Technical Library
  • Technical Library
Technical Library
Documents NXP: Using the SCT in LPCxpresso, Keil, and IAR_
  • Author Author: vandana
  • Date Created: 25 Sep 2012 3:27 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:39 AM
  • Views 338 views
The State Configurable Timer (SCT) allows a wide variety of timing, counting, output modulation, and input capture operations.
LPCXpresso incorporates a graphical tool for designing state machines and can generate the code required to implement the SCT. This application note will describe a process to use the code generated by LPCXpresso to add SCT functionality into Keil and IAR IDEs.
AN11161_v1.zip
  • Application Library
