Technical Library
  • Technical Library
Technical Library
Documents ARM: ULINK Debugger Comparison
  • Author Author: Yiying
  • Date Created: 2 Jan 2014 9:21 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:47 AM
  • Views 1374 views
A comparison of all ULINK adapters
FeatureULINKproULINKpro DULINK2ULINK-MEULINK
Debugging Features
RAM BreakpointsUnlimitedUnlimitedUnlimitedUnlimitedUnlimited
ROM Breakpoints (ARM7/9)2 max2 max2 max2 max2 max
ROM Breakpoints (Cortex-M3)8 max8 max8 max8 max8 max
ROM Breakpoints (µPSD)
(Cannot Set While Executing)
----5 max--5 max
ROM Breakpoints (XC800)
----4 max--4 max
ROM Breakpoints (XC166)----4 max--4 max
Execution Breakpoints
(Set While Executing)
YYYYY
Access Breakpoints (ARM7/9)2 max
(R/W Only, With Value)
2 max
2 max
2 max
2 max
Access Breakpoints (Cortex-M3)4 max
(With value)
4 max
(With value)
4 max
(With value)
4 max
(With Value)
N
Access Breakpoints (µPSD)----3 max--3 max
Access Breakpoints (XC800)----1 in IDATA max--1 in IDATA max
Access Breakpoints (XC166)----1 max--1 max
Debugging Support
Real-Time Agent (ARM7/9)NNYYN
Serial Wire Debug (Cortex-M)YYYYN
Data Trace (Cortex-M3/M4)
(Serial Wire Viewer)
YYYYN
Instruction Trace (Cortex-M3/M4)
(Embedded Trace Macrocell - ETM)
YNNNN
Performance
JTAG Clock<=50MHz<=50MHz<=10MHz<=10MHz<=1MHz
Memory R/W≈ 1MB/s≈ 1MB/s≈ 28KB/s≈ 28KB/s≈ 28KB/s
Flash R/W32KB/s32KB/s≈ 25KB/s≈ 25KB/s≈ 15KB/s
Data Trace Streaming800Mb/s800Mb/s1Mb/s1Mb/sN
Connectors
10-pin (0.05")
(Cortex Debug Connector)
YYYYN
20-pin (0.1")
(ARM Standard JTAG Connector)
YYYYY
20-pin (0.05")
(Cortex Debug+ETM Connector)
YYNNN
16-pin (0.1")
(Infineon OCDS Connector)
NNYNY
14-pin (0.1")
(ST µPSD Connector)
NNYNY
I/O Voltage Range1.2V - 3.3V1.2V - 3.3V2.7V - 5.5V3.0V - 3.6V3.0V - 5.5V
Supported Device Families
XC800 (8051)NNYNY
µPSD (8051)NNYNY
XC166/XE166/XC2000NNYNY
LPC950 (8051)NNYYY
ARM7YYYYY
ARM9YYYYY
Cortex-M0YYYYN
Cortex-M0+YYYYN
Cortex-M1YYYYN
Cortex-M3YYYYN
Cortex-M4YYYYN
  • ulinkpro_d
  • keil_ulink
  • ulink2
  • ulink
  • ulinkpro
  • ulink-me
