Technical Library
  • Technical Library
Technical Library
Documents tiny size and great concept: SSD. check it out!
  • Author Author: DebuggerGuys
  • Date Created: 2 May 2012 9:42 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:51 AM
  • Views 845 views
Fitting a truly quick solid-state drive into a small space isn't easy, and for that reason RunCore's new Mini DOM (Disk On Module) stands out from the crowd.
It's billed as the first single-chip SSD to use a SATA interface (SATA II, to be exact), giving it that much more bandwidth than the pokey IDE and PATA DOMs of old while remaining under half the size of a regular mSATA drive.
RunCore's own tests show it hitting about 113MB/s sequential reads and 47MB/s writes.
Neither figure will knock the socks off even a mainstream budget SSD like Intel's SSD 330, but they're more than brisk enough for embedded gear.
The drives can survive brutal conditions, too: an Industrial Grade trim level can survive temperatures as chilly as -40F and as scorching as 185F.
So, the next time you pry open some military equipment and see one of these sitting inside, in three different formats and capacities from 8GB to 64GB, you'll know exactly what you're looking at.
keep reading more of this cool drive on Engadget! and find more interesting content with DebuggerGuys.
  • solid-state
  • runcore
  • minidom
  • ssd
  • dom
  • military
  • industrial
  • ii
  • drive
  • flashdrive
  • codewarrior
  • embedded
  • solid-statedrive
  • sataii
  • flash
  • solidstatedrive
  • mini
  • solid
  • state
  • sata
