Technical Library
  • Technical Library
Technical Library
Documents Microchip: PIC32 USB Starter Kit II (BOM added)
  • Author Author: Oliver
  • Date Created: 10 May 2012 5:33 AM Date Created
  • Last Updated Last Updated: 26 Jun 2012 6:27 PM
  • Views 1420 views
  • Design Elements
  • Video
  • Features
  • BOM List
Fullscreen 0525.contentimage_17869.html Download
<html><head><title>Jive SBS</title></head>
<body><font face="arial,helvetica,sans-serif">
<b>Error</b><br><font size="-1">
An general error occurred while processing your request.
</font></font></body></html>
The Microchip’s DM320003-2DM320003-2 USB Starter Kit II provides a low-cost, modular development system for Microchip’s line of 32-bit microcontrollers (MCUs). The starter kit comes preloaded with demonstration software for the user to explore the new features of the PIC32. It is also expandable through a modular expansion interface, which allows the user to extend its functionality. The starter kit also supplies on-board circuitry for full debug and programming capabilities.
The PIC32 USB Starter Kit II provides the easiest and lowest cost method to experience the USB and CAN functionality of the PIC32 microcontrollers. Users can develop CAN applications using PIC32 expansion board. The board contains everything need to develop USB embedded host/device/OTG applications by combining this board with Microchip's free USB software. The USB Starter Kit II has the same form factor and expansion connector as other PIC32 Starter Kits. All project files have been included so that the code may be used directly to restore the PIC32 MCU on the starter kit to its original state (i.e., if the sample device has been reprogrammed with another program).
Learning Center
TypeDescription
User GuideMicrochip: User Guide for PIC32 Starter Kit
Application NotesMicrochip: AN1111 - FTP Server using BSD Socket API
Application NotesMicrochip: AN1109 - SNMP Agent using BSD Socket API
Product BriefMicrochip: Product Brief for PIC32 Microcontroller Families
Back to top
Design Elements
TypeDescription
User GuideMicrochip: Quick Start to Guide to Microchip Development Tools
User GuideMicrochip: Software Solutions and Tools for the 16-bit and 32-bit Designer
SchematicMicrochip: Schematics for Starter Kit I/O Expansion Board
Appliation libraryMicrochip: Software code for PIC32 ESK PWM/DMA Demo
Appliation libraryMicrochip: Software code for PIC32 CAN to Ethernet Bridge Demo
Back to top
Video
Back to top
Features
  • PIC32MX795F512LPIC32MX795F512L 32-bit microcontroller.
  • Green power indicator LED.
  • On-board crystal for precision microcontroller clocking (8 MHz).
  • USB connectivity for on-board debugger communications.
  • Orange debug indicator LED.
  • Three push button switches for user-defined inputs.
  • Three user-defined indicator LEDs.
  • USB Type A receptacle connectivity for PIC32 host-based applications.
  • HOST mode power jumper.
Kit Content
  • PIC32 USB Starter Kit II Development Board
  • USB mini-B to full-sized A cable – USB debug cable to debug and power the board
  • USB micro-B to full-sized A cable – PIC32 USB cable to communicate with the PIC32 USB port
Key Applications
  • Automotive
  • Wireless Connectivity
  • Wired Connectivity
Back to top
BOM List
S/NRef DesQ'tyMfr.Mfr. Part NumberDescriptionPreferred Status
1U11IC SMT, PIC32MX440F512H-80I/MR 64P QFN
MICROCHIPPIC32MX440F512H-80I/MRPIC32MX440F512H-80I/MRPreferred
2U21IC SMT, PIC32MX795F512L 100L TQFP
MICROCHIPPIC32MX795F512L-80I/PTPIC32MX795F512L-80I/PTPreferred
3U41IC SMT, MCP1253,DC/DC Converter 3.3V 8L MSOP
MICROCHIPMCP1252-33X50I/MSMCP1252-33X50I/MSAlternate
MICROCHIPMCP1253-33X50I/MSMCP1253-33X50I/MSPreferred
4U51IC SMT, TC1262-3.3VDBTRTC1262-3.3VDBTR, SOT-223
MICROCHIPTC1262-3.3VDBTRTC1262-3.3VDBTRPreferred
MICROCHIPMCP1825S-3302E/DBMCP1825S-3302E/DBAlternate
MICREL SEMICONDUCTORMIC5209-3.3YSMIC5209-3.3YSAlternate
5U61IC SMT, TPS20X1 0.75A Power Dist Switch 5-SOT23
TEXAS INSTRUMENTSTPS2051BDBVRTPS2051BDBVRPreferred
TEXAS INSTRUMENTSTPS2051CDBVTTPS2051CDBVTAlternate
6U71IC SMT, TPS2041BD..TPS2041BD.. 1A PWR Dist Switch SNGL SOT23-5
TEXAS INSTRUMENTSTPS2065CDBVTTPS2065CDBVTAlternate
TEXAS INSTRUMENTSTPS2041BDBVRTPS2041BDBVRPreferred
7Y1,Y22OSC SMT, 8.0 MHz Crystal 20PF
IQD FREQUENCY PRODUCTS12SMX (B) 30/5020/16 8.0 MHZ12SMX (B) 30/5020/16 8.0 MHZAlternate
EUROQUARTZ8.000MHZ MQ/30/30/40/12PF8.000MHZ MQ/30/30/40/12PFAlternate
AKERC7S-8.000-12-3030-XC7S-8.000-12-3030-XAlternate
FOX ELECTRONICSFQ7050B-8FQ7050B-8Preferred
8S1,S2,S33Switch, Light Touch 160 gF
ALPSSKQYAAE010SKQYAAE010Preferred
9J11CONN SMT, RECPT, USB Mini-B 5POS RA
KYOCERA24 5141 005 000 863+24 5141 005 000 863+Alternate
SAMTECMUSB-05-S-B-SM-AMUSB-05-S-B-SM-AAlternate
SAMTECMUSB-05-S-AB-SM-AMUSB-05-S-AB-SM-AAlternate
TE CONNECTIVITY1734035-11734035-1Alternate
TE CONNECTIVITY1734035-21734035-2Alternate
MOLEX56579-057656579-0576Alternate
MOLEX548190572548190572Preferred
10J21CONN, SMT, HDR, 120P, W/Post
HRS (HIROSE)FX10A-120P/12-SV1(71)FX10A-120P/12-SV1(71)Preferred
11J41CONN, RECPT, USB TYPE-A w/Board Lock
TE CONNECTIVITY1734366-11734366-1Alternate
TE CONNECTIVITY1903814-11903814-1Alternate
LUMBERG2410 022410 02Alternate
WUERTH ELEKTRONIK6140041602161400416021Alternate
SAMTECUSBR-A-S-S-O-THUSBR-A-S-S-O-THAlternate
FCI87520-0010BLF87520-0010BLFPreferred
12J51CONN, RECPT, USB Micro-B R/A
TE CONNECTIVITY1981584-11981584-1Alternate
MOLEX47346-000147346-0001Alternate
MOLEX47590-000147590-0001Alternate
HRS (HIROSE)ZX62-AB-5PAZX62-AB-5PAPreferred
13JP21CONN, HDR, 1x2 Breakaway, 0.100" Pitch
TE CONNECTIVITY826926-2826926-2Alternate
TE CONNECTIVITY826629-2826629-2Alternate
TE CONNECTIVITY825433-2825433-2Alternate
MOLEX22-29-202122-29-2021Alternate
MOLEX22-03-202122-03-2021Alternate
MOLEX90120-076290120-0762Preferred
14JP21CONN, Shunt, 2-Pin Shorting Shunt (.100" Spacing)
TE CONNECTIVITY0-0142270-30-0142270-3Alternate
FCI68786-20268786-202Alternate
TE CONNECTIVITY827914-1827914-1Alternate
FISCHER ELEKTRONIKCAB 4 GSCAB 4 GSAlternate
JSTJM-2BK-61JM-2BK-61Alternate
HARWINM7566-05M7566-05Alternate
HARWINM7565-05M7565-05Alternate
HARWINM7571-05M7571-05Alternate
HARWINM7567-05M7567-05Preferred
15D1,D52LED SMT, 0805 Yellow DIFF 2x1.25 mm Thin
KINGBRIGHTKP-2012YCKP-2012YCAlternate
LUMEXSML-LX0805YC-TRSML-LX0805YC-TRAlternate
LUMEXSML-LXT0805YW-TRSML-LXT0805YW-TRPreferred
16D2,D72DIODE SMT, Schottky 30V 0.5A SOD-123
TAIWAN SEMICONDUCTORB0530WB0530WAlternate
ON SEMICONDUCTORMBR0530T1GMBR0530T1GAlternate
DIODESB0530W-7-FB0530W-7-FPreferred
17D3,D62LED SMT, 0805 Green DIFF 2x1.25mm
LUMEXSML-LXT0805GW-TRSML-LXT0805GW-TRAlternate
KINGBRIGHTKP-2012SGCKP-2012SGCAlternate
LUMEXSML-LXT0805GW-TRSML-LXT0805GW-TRPreferred
18D41LED SMT, 0805 Red DIFF 2x1.25 mm Thin
LUMEXSML-LXT0805IW-TRSML-LXT0805IW-TRAlternate
ROHMSML-210VTT86LSML-210VTT86LAlternate
ROHMSML-212VTT86SSML-212VTT86SAlternate
KINGBRIGHTKP-2012SURCKKP-2012SURCKAlternate
LUMEXSML-LXT0805IW-TRSML-LXT0805IW-TRPreferred
19R10,R13,R14,R16,R185RES SMT, 4.7KΩ 1/10W 5% 0603
BOURNSCR0603-JW-472ELFCR0603-JW-472ELFAlternate
VISHAY DRALORICCRCW06034K70JNEACRCW06034K70JNEAAlternate
VISHAY DRALORICCRCW06034K70JNEAIFCRCW06034K70JNEAIFAlternate
MULTICOMPMC 0.063W 0603 5% 4K7MC 0.063W 0603 5% 4K7Alternate
YAGEORC0603JR-074K7LRC0603JR-074K7LAlternate
PANASONICERJ-3GEYJ472VERJ-3GEYJ472VPreferred
20R171RES SMT, 100 KΩ 1/10W 1% 0603
TE CONNECTIVITYCPF0603F100KC1CPF0603F100KC1Alternate
BOURNSCR0603-FX-1003ELFCR0603-FX-1003ELFAlternate
VISHAY DRALORICCRCW0603100KFKEACRCW0603100KFKEAAlternate
VISHAY DRALORICCRCW0603100KFKEAHPCRCW0603100KFKEAHPAlternate
VISHAY DRALORICCRCW0603100KFKTACRCW0603100KFKTAAlternate
PANASONICERJP03F1003VERJP03F1003VAlternate
MULTICOMPMC0603WGF1003T5E-TRMC0603WGF1003T5E-TRAlternate
MULTICOMPMCHP03W8F1003T5EMCHP03W8F1003T5EAlternate
YAGEORC0603FR-07100KLRC0603FR-07100KLAlternate
YAGEORT0603FRE07100KLRT0603FRE07100KLAlternate
WELWYNWCR0603-100KFIWCR0603-100KFIAlternate
PANASONICERJ-3EKF1003VERJ-3EKF1003VPreferred
21R5,R19,R20,R22,R235RES SMT, 330Ω 1/10W 5% 0603
VISHAY DRALORICCRCW0603330RJNEACRCW0603330RJNEAAlternate
VISHAY DRALORICCRCW0603330RJNEAIFCRCW0603330RJNEAIFAlternate
BOURNSCR0603-JW-331GLFCR0603-JW-331GLFAlternate
YAGEORC0603JR-07330RLRC0603JR-07330RLAlternate
MULTICOMPMC 0.063W 0603 5% 330RMC 0.063W 0603 5% 330RAlternate
PANASONICERJ-3GEYJ331VERJ-3GEYJ331VPreferred
22R9,R11,R12,R154RES SMT, 1.0 KΩ 1/10W 5% 0603
VISHAY DRALORICCRCW06031K00JNEACRCW06031K00JNEAAlternate
BOURNSCR0603-JW-102GLFCR0603-JW-102GLFAlternate
MULTICOMPMC 0.063W 0603 5% 1KMC 0.063W 0603 5% 1KAlternate
YAGEORC0603JR-071KLRC0603JR-071KLAlternate
PANASONICERJ-3GEYJ102VERJ-3GEYJ102VPreferred
23
C1,C9,C10,C11,C13,
C30,C19,C20,C21,
C22,C23,C24
12CAP SMT, 0.1 µF 0603 CER 16V 10% X7R
AVXCM105X7R104K16ATCM105X7R104K16ATAlternate
AVX0603YC104K4Z2A0603YC104K4Z2AAlternate
AVX0603YC104KAT2A0603YC104KAT2AAlternate
AVX0603YC104JAT2A0603YC104JAT2AAlternate
AVX0603YC104KAZ2A0603YC104KAZ2AAlternate
KEMETC0603X104K4RACTUC0603X104K4RACTUAlternate
KEMETC0603C104K4RACTUC0603C104K4RACTUAlternate
MULTICOMPC0603C104J4RACTUC0603C104J4RACTUAlternate
MULTICOMPMCCA000159MCCA000159Alternate
MULTICOMPMCCA001147MCCA001147Alternate
MULTICOMPB0603R104KCTB0603R104KCTAlternate
YAGEOCC0603KRX7R7BB104CC0603KRX7R7BB104Alternate
AVX0603YC104K4T4A0603YC104K4T4APreferred
24C171CAP SMT, 1.0 µF 0805 CER 16V 10% X7R
KEMETC0805X105K4RACTUC0805X105K4RACTUAlternate
KEMETC0805C105K4RAC AUTOC0805C105K4RAC AUTOAlternate
MURATAGRM21BR71C105KA01LGRM21BR71C105KA01LAlternate
KEMETC0805C105K4RACTUC0805C105K4RACTUPreferred
25C2,C292CAP SMT, 10 µF 0805 CER 6.3V 20% , X5R
TAIYO YUDENJMK212BJ106KD-TJMK212BJ106KD-TAlternate
TAIYO YUDENJMK212BJ106KG-TJMK212BJ106KG-TAlternate
MULTICOMPMCCA000593MCCA000593Alternate
MURATAGRM219R60J106KE19DGRM219R60J106KE19DAlternate
JOHANSON DIELECTRICS6R3R15X106KV4E6R3R15X106KV4EAlternate
KEMETC0805C106K9PACTUC0805C106K9PACTUAlternate
AVX08056D106KAT2A08056D106KAT2APreferred
26C251CAP SMT, 6.8uF 0805 CER 6.3V 10% X5R
KEMETC0805C685K9PACTUC0805C685K9PACTUPreferred
27C261CAP SMT, 100 µF 1812 CER 6.3V -20%,+80% Y5V
TDKC4532X5R0J107MC4532X5R0J107MAlternate
MURATAGRM43SR60J107ME20LGRM43SR60J107ME20LAlternate
JOHANSON DIELECTRICS6R3S43X107MV4E6R3S43X107MV4EPreferred
28C3,C4,C5,C64CAP SMT, 20 pF 0603 CER 50V, 5% C0G
TDKC1608C0G1H200JC1608C0G1H200JAlternate
YAGEOCC0603JRNPO9BN200CC0603JRNPO9BN200Alternate
KEMETC0603C200J5GACTUC0603C200J5GACTUPreferred
29C7,C82CAP SMT, 4.7 µF 0805 CER 16V +80-20% Y5V
MURATAGRM21BF51A475ZA01LGRM21BF51A475ZA01LAlternate
MULTICOMPMCCA000540MCCA000540Alternate
MULTICOMPMCCA000595MCCA000595Alternate
AVX0805ZG475ZAT2A0805ZG475ZAT2APreferred
30
C15,C16,C18,GND1,
J3,R24,R27,TP9,
TP10,Y3
——Spare Location, Do Not Install
Back to top
  • microchip
  • bomlist
  • usb
  • developement_kit
  • evalution_kit
  • developpement-tools
  • eval_board
  • pic32
  • can
