Technical Library
  • Technical Library
Technical Library
Documents freescale's CodeWarrior updates! (EWL C Reference)~
  • Author Author: DebuggerGuys
  • Date Created: 29 May 2012 10:19 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:53 AM
  • Views 1004 views
The CodeWarrior C and C++ compilers use the Embedded Warrior Library (EWL) for C to provide and extend the libraries documented in the ISO/IEC standards for C. EWL C also offers facilities described in the POSIX specification and some common application programming iwnterfaces (APIs) from UNIX operating systems.
Intrinsic functions generate in-line assembly code instead of making a call to a library function. Intrinsic functions generate less object code and perform faster than their regular counterparts. In some cases these functions generate just a single assembly instruction. Get the EWL for C   n o w !
Tumblr_m26i0qxhtn1rsm53yo1_500_large
For the EWL C++ reference libraries you can also find:
  • The EWL C++ Library Overview of thismanual describes the language support library that provides components that are required by certain parts of the C++ language, such as memory allocation and exception processing.
  • “LanguageSupport Library” discusses the ANSI/ISO language support library.
  • Diagnostics Library elaborates on the diagnostics library that provides a consistent framework for reporting errorsina C++ program, including predefined exception classes.
  • General Utilities Libraries discusses the general utilities library, which includes components used by other library elements, such as predefined storage allocator for dynamic storage management.
  • Strings Library discusses the strings components provided for manipulating text represented as sequences of type char, sequences of typewchar_t, or sequences of any other “character-like” type.
...and so on! Find out what the rest of the libraries have got to give you to improve and update CodeWarrior tools! Check out the manual here!
  • c
  • ewl
  • freescale
  • reference
  • codewarrior
  • c++
