EAGLE User Chat (English) Version control
  • Replies 17 replies
  • Subscribers 189 subscribers
  • Views 2611 views
Version control
I am a one man shop, nonetheless, I find I need to establish some kind of
revision control. I'm struggling trying to find the best way in Eagle to
keep track of notes, changes, etc.
1. I'd like to have a way to automatically/easily bump the revision of a
schematic/PCB. Something like version control in software design.
2. I'd like a straightforward way to track the changes and keep notes and
comments. It's a pain to add text one line at a time on the schematic
itself and I find the supplied "frames" to be a bit cumbersome to use.
I've struck out trying to find anything in the user manual or in the list.
I've looked through the download section for ULPs, but didn't find
anything.
I find I'm already getting lost in revisions.
Thanks for any advice.
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Robert Pearce wrote:
    >Bill Westfield wrote :
    >>SVN seems awfully complex for a one-man shop;
    >Nonsense! SVN is really easy once set up, and even the server admin
    >isn't hard. I use it for all my stuff, and I'm a "one man shop". It's
    >easier than RCS.
    >I haven't checked, but I suspect the fixed length keyword mechanism
    >would work in Eagle files (it does in MS Office, where normal keywords
    >kill files big time). That would allow the latest version to be
    >automatically included in your schematic etc.
    sadly keyword expansion doesn't work. It messes with eagles licence
    mechanism.
    And I'm still looking for a usable diffing tool for eagle schematic
    and board files 8-)
    Lorenz
    e14 Contributor over 16 years ago in reply to WestfW
    On Tue, 29 Jun 2010, Bill Westfield wrote to us saying :
    easier than RCS.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
  • WestfW
    WestfW over 16 years ago in reply to e14 Contributor
    Eagle lets you add a description to a project directory, but not to
    the files within a project.
    Um, there are "layers"!  I've been adding an "Edit history" layer to
    boards (also applicable to schematics), and keeping it updated manually.
      It requires some discipline (but does does any version control
    mechanism), but it's pretty useful.  Naturally, you have the automatic
    backups that EAGLE makes to save yourself from errors, and can
    periodically rename to new version numbers or use conventional version
    control tools to preserve old or intermediate versions.
    SVN seems awfully complex for a one-man shop; I've been experimenting
    with RCS (a sort of grand-daddy of version control tools.)  It should be
    possible to stick some ULPs and more automatic tools around the tool,
    the layer, and perhaps some "components" that store version information,
    but I haven't gotten very far...
    http://picasaweb.google.com/westfw/ArduinoStuff#5488437935770995842
    Jorge Garcia wrote on Tue, 29 June 2010 11:41
    kind of
    Eagle to
    of a
    notes and
    schematic
    use.
    the list.
    anything.
    Hi David,
    Why not simply use a version control program. I've communicated with
    several engineers and most of them recommend Subversion. It's open
    source (Free) and does a good job. If you like to use a GUI interface
    then Tortoise SVN or Rabbit SVN might be a good choice.
    Hth,
    Jorge Garcia
    Hi Jorge,
    To answer your question, because I hadn't even thought about a version
    control wrapper around my Eagle projects. Thanks for the idea. I took a
    look at Subversion. It would certainly track the file versions, etc. but it
    still doesn't do what I was wanting. I was really hoping Eagle had built
    into it a way to track revisions and notes as part of the schematic/PCB
    file itself. It looks like Subversion is just a wrapper on the outside.
    I wanted the ability to mimic a paper system. Where a schematic is copied,
    changes are made to the copy, the version is bumped, and notes/dates are
    added to the drawing to indicate what was done and why.
    Like, Eagle lets you add a description to a project directory, but not to
    Thanks again.
    anything.
    Hi David,
    Hth,
    Jorge Garcia
    warrenbrayshaw wrote on Mon, 28 June 2010 21:32
    "David Ingebretsen" wrote
    ................ I find I need to establish some kind of
    Eagle to
    of a
    notes and
    schematic
    use...........
    David
    I feel a ULP could be built that locates the REV: box on the
    schematic,
    presents the current content and  a box to enter the new text. On exit
    from
    the ULP, the Schematic is updated.
    The same is true for a 'Document Number" box. But this entales the
    same
    number of actions to achieve as manually making the changes. There
    would
    also need to be consistancy with the frames used.
    Notes on the schematic could also be done via a ULP if you used a
    dedicated
    notes area like the frame documentation area. The ULP could find this
    area,
    present the current info and then you could type into a dialog  the
    new
    record. At least you could type it all in one go rather than line by
    line.
    All the above is  recorded on the schematic.
    The ULP could be extended to save the current schematic with a new
    version
    name so you save a file of each version. Then I guess you could connect
    the
    History text to yet another text file, One for each project that is a
    collection of all the Version notes that have been added to each of
    the
    schematics in this project. History text per board rather than one per
    project could be achieved as well. You would need to dig them out of
    the
    project folder to review when required.
    Maybe someone has done something similar already
    Warren
    Thanks Warren. I take it then there is no preferred or recommended way to
    control revisions and notes with Eagle. I'll have to give this more thought
    before I proceed with the project. I just don't want a bunch of
    schematic/PCB files and all the automatic backup files Eagle makes with no
    idea which is which and what ones I want to keep and which can be deleted.
    I appreciate the thoughts, thanks again.
    David
    use...........
    David
    I feel a ULP could be built that locates the REV: box on the schematic,
    presents the current content and  a box to enter the new text. On exit from
    The same is true for a 'Document Number" box. But this entales the same
    number of actions to achieve as manually making the changes. There would
    Notes on the schematic could also be done via a ULP if you used a dedicated
    notes area like the frame documentation area. The ULP could find this area,
    present the current info and then you could type into a dialog  the new
    record. At least you could type it all in one go rather than line by line.
    The ULP could be extended to save the current schematic with a new version
    name so you save a file of each version. Then I guess you could connect the
    collection of all the Version notes that have been added to each of the
    project could be achieved as well. You would need to dig them out of the
    Warren
