EAGLE User Chat (English) Pinout on 555/Linear devices
  • Subscribers 177 subscribers
  • Views 401 views
I'm wondering why the pinout on the all the 555 timers in the linear
library reads (anti-clockwise): 2,4,5,1,8,6,7,3 - as opposed to
1,2,3,4,5,6,7,8?
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
    1,2,3,4,5,6,7,8?
    A schematic symbol is normally drawn such that the pin layout makes sense
    for drawing the schematic, ideally with a left to right signal flow.  The
    physical pin layout is irrelevant.
    The situation is pretty much the same for every IC. Perhaps your confusion
    arises in this case as the symbol is drawn with a similar structure to the
    physical part, whereas with an op amp or more complex IC it may not cross
    your mind.
    David
    linear library reads (anti-clockwise): 2,4,5,1,8,6,7,3 - as opposed
    to 1,2,3,4,5,6,7,8?
    Perhaps your confusion arises in this case as the symbol is drawn
    with a similar structure to the physical part, whereas with an op amp
    or more complex IC it may not cross your mind.
    Good point - thanks.
