EAGLE User Chat (English) Eagle 3D for Mac?
  • Replies 17 replies
  • Subscribers 189 subscribers
  • Views 3160 views
Eagle 3D for Mac?
Where do I find Eagle 3D for the Mac platform? None of the links I come
across work and I'm pretty sure that I remember having installed it on a
Mac several years ago.
Does anyone know where I can find it, and presumably a version which
works with Eagle 7.3.0. Light on OSX 10.9.5 which I'm using now?
Thanks.
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Just to clarify if anybody else is interested in giving www.ecad.io a try - it only reads Eagle files saved as version 6 onwards. We looked at the files causing the problem above, and although they'd been opened in version 7, they'd been created in version 5 or earlier and had never been saved in v7 and converted to the v7 format.
    Hence, if you get a loading error with your Eagle files and think they may have been created before version 6, then please try saving them in version 6 and later and then retry. The loading error isn't very informative at present (it'll say something like 'Syntax error on line 0. There is an error in XML document'), so we'll look at making this a little more user friendly.
    If anybody's having problems with later Eagle files then please let me know and we'll try our best to help. Thanks!
    e14 Contributor over 10 years ago in reply to autodeskguest
    Many thanks for giving it a try. The issue sounds like it may be a problem with the encryption of Mac Eagle files. I've tried the site on a Mac using Eagle 7 files and it worked for me, but the files in question were from the PC version of Eagle. I'll get hold of a Mac version of Eagle and give it a try here.
    Meanwhile would it be possible for you to send me some of the files that are failing? We'd keep their contents confidential and only use them for testing this issue. You can email me directly at robert(dot)lacey(at)autodesk(dot)com.
    Incidentally, have you tried it with IDF files from Eagle on a Mac? Again, I'll give that try here too today. IDF's a much more straightforward format, so hopefully that'll work (although you won't get as much detail as you would with native Eagle files of course).
    Thanks again,
    Rob
    autodeskguest over 10 years ago in reply to e14 Contributor
    On 11/09/2015 15:53, Rob Lacey wrote:
    The site is www.ecad.io - it'll accept Eagle files from v6 onwards, as
    well as IDF and IPC2581 files and generate 3D models.
    This sounds interesting, but apart from a few downloaded Eagle files
    from others I couldn't get any of my own .BRD files to work. All I got
    were error messages:
       Syntax error on line 0. There is an error in XML document (1, 1).
    I'm using Eagle 7.3.0 (Mac). What am I doing wrong?
    e14 Contributor over 10 years ago in reply to Joop14
    No problem Joop - I realise the fact it's cloud-based may be a limitation for some users.
    If security's a concern, the site has an SSL certificate and any uploaded data is encrypted and not retained online if you don't want it to be.
    Cheers,
    Rob
  • Joop14
    Joop14 over 10 years ago in reply to e14 Contributor
    Rob Lacey wrote:
    We've been working on an online ECAD to MCAD tool...
    Thanks, but no. Those tools (preferable open-source) need to be run natively on my pc without the need for internet-access.
    Kind Regards,
    Joop
    Hi all - new forum member here.
    We've been working on an online ECAD to MCAD tool which may help in this situation, as it works with both PC and Mac. It's still a bit of a work in progress, so I can't guarantee it'll work perfectly just yet, but I'd value the feedback if anybody wants to give it a try.
    The site is www.ecad.io - it'll accept Eagle files from v6 onwards, as well as IDF and IPC2581 files and generate 3D models. Currently it's only outputting STEP, but we should have STL and IGES output up and running pretty soon. We've got a database of a fair few detailed components in already for users that want detailed component models, although we've got a lot more to add. You can just use the 'simple' footprint shape if we've not got a detailed model.
    One thing we support is sending models straight to an online MCAD system or Cloud Drive which some people may find useful - so far we can send STEP files to Google Drive, Microsoft OneDrive and Onshape. We'll hopefully also have support for other cloud MCAD including Autodesk Fusion 360 before too long too.
    The site's free to use and hopefully it'll be of use to some of you - please let me know here or via the 'Contact Us' on the website if you have thoughts or feedback.
    Many thanks,
    Rob
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 25.08.2015 um 14:36 schrieb Logyx:
    Now the 3D POV file has been created and can be opened with POVRay (3.7
    unofficial) to create the final 3D image file.
    Hi Logyx,
    Unfortunately I have no mac, so I can not try it.
    On Windows, in Povray GUI I can override the default values. I
    give the name of a preference file. In my case: Eadle3D.ini. The
    file has the following contents.
    ;path to Windows font directory
    Library_Path=C:\WINDOWS\Fonts
    ;path to INC files
    Library_Path=C:\Daten\MATTHIAS\POVRay\eagle3D\inc
    ;this is the target for generated images
    ;if this section is commented out, it will be written
    ;into the POVRay file directory
    Output_File_Name=c:\temp\povout\
    ;Format of the image file
    Output_File_Type=S
    ;Type N for PNG
    ;Type S for standard system format (Windows BMP, Mac Pict ...)
    ;Type C for compressed Targa (RLE)
    ;TypeT for uncompressed Targa
    ;Type P for Unix PPM
    ;Settings for animations
    Initial_Frame = 1
    Final_Frame = 1
    Initial_Clock = 0.0
    Final_Clock = 1.0
    I have found an older user guide: eagle3d_e.pdf
    https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCMQFjAAahUKEwj4k6CBwMfHAhVoJnIKHdnTD7E&url=https%3A%2F%2Fdocs.google.com%2Fviewer%3Fa%3Dv%26pid%3Dsites%26srcid%3DZGVmYXVsdGRvbWFpbnxsdWNhcm9ib3R8Z3g6NzIyODg1MzY5YTlmMzc2MQ&ei=zRXeVbj5AujMyAPZp7-ICw&usg=AFQjCNGSS0BM_QPlo21Jd8-_sF5lkbYxKA
    Here you get a GUI for the Mac
    http://megapov.inetart.net/povrayunofficial_mac/index.html
    The file arrays.inc should be located in the directory
    POV-Ray/v3.7/include
    PS: shouldn't the content of the Eagle3D ULP folder be copied over to
    Eagle's own ULP folder or is it correct to have two ULP folders?
    For clarity I would put the 3dulp in its own directory.
    Friedrich
    On 21/08/2015 23:18, Friedrich Bleikamp wrote:
    you need the file
    http://sourceforge.net/projects/eagle3d.berlios/files/eagle3d_20110101.zip/download
    Thanks. No wonder it didn't work. I still have some problems and am not
    sure where to look. More about that below, but just to avoid any
    confusion and assure I've installed everything correcly, this is what
    I've done (I have Eagle 7.3.0 on the Mac OSX platform):
    1) download and unzip the Eagle3D image files:
    2) download and unzip the Eagle 3D application files:
    3) move the Eagle3D application files to inside my Eagle application
    folder: /Applications/Eagle-7.3.0/eagle3d/
    4) move all the Eagle3D image files (.png) to a newly created "img"
    folder, the complete path being:
    /Applications/Eagle-7.3.0/eagle3d/ulp/img/
    So now Eagle3D should be installed correctly. Next is creating the 3D
    POV file from within Eagle.
    1) In Eagle, open a board file
    2) Click on the "ULP" icon, select "3d50.ulp" (now located here:
    /Applications/Eagle-7.3.0/eagle3d/ulp/) to create the file
    unofficial) to create the final 3D image file. Here's where I run into
    problems with this error message:
    Possible Parse Error: Cannot find file 'arrays.inc', even after trying
    to append file type extension.
    "/Applications/EAGLE-7.3.0/Eagle3D/povray/e3d_tools.inc"
      line 25
    Parse Error: Cannot open include file arrays.inc.
    Render failed
    autodeskguest over 11 years ago in reply to autodeskguest
    Am 20.08.2015 um 13:17 schrieb Logyx:
    On 10/08/2015 23:46, Jorge Garcia wrote:
    I'm a little confused about the installation and usage process..
    I've downloaded both POVray (3.7 Mac Unofficial) and Eagle3D
    (eagle3d-img-20110101) from the above links.
    I should have a file named "3d41.ulp" or "3d40.ulp" in my "ULP" folder
    (alongside the Eagle application) but there's no such file pre-installed
    with Eagle nor is it found in the Eagle3D folder.
    Hi Logyx,
    you need the file
    Unzip it in a location of your choice.
    Move the images you have downloaded, to a subfolder
    'eagle3d/ulp/img'.
    In the eagle-board-editor open the ULP
    'your_location/eagle3d/ulp/3d50.ulp' for 'cadsoft eagle V5' and
    newer.
    At the first use, you have to configure the ULP.
    My English is not very good, but I hope I could you help anyway.
    Friedrich
    POVray is a stand-alone application apparently which I've put in the
    "Applications" folder on my Mac, but as for Eagle 3D I only see a folder
    with loads of .PNG files after unzipping it. According to the
    Instructables guide
    (http://www.instructables.com/id/Render-3D-images-of-your-PCBs-using-Eagle3D-and-PO/?ALLSTEPS)
    Hi Logyx,
    Well that's terrible, I don't have any files for that project and it
    looks like the original site stopped being hosted.I was hoping the ULP
    would be included in the files on that site.
    I'm going to have to defer to other members of the forum to see if any
    of them have a saved version of the utility.
    hth,
    Jorge Garcia
