EAGLE User Chat (English) Hard Lessons Learned (watch out for land mines)
  • Replies 17 replies
  • Subscribers 183 subscribers
  • Views 2019 views
  • watch
  • landmines
  • for
  • out
So here is my experience with Eaglesoft and Element14 so far and some land mines you may encounter and how to avoid them.  First of all, the libraries that are provided with the software should be immediately discarded.  Don't keep any of them, since you will either end up designing boards that use over priced parts or parts that Element 14 does not have.  Expecially avoid any parts by Farnell, since they don't sell their parts cheap nor do their libraries contain parts that they actually sell.
You are better off discarding their libraries and developing your own.  It is not hard to make a part in Eagle cad and if you source your parts and make the designs yourself you won't be disappointed by the irresponsible curation of non existent parts in the default libraries.
  • kikoun
    kikoun over 10 years ago in reply to shabaz +2
    I never use Eagle library, at least without editing . Years ago I used to copy a device from Eagle lib, then checked and edit the copy. But today I prefer create build the device from scratch, or by using…
    michaelkellett over 10 years ago in reply to shabaz +2
    I'll chip in here although I don't use Eagle because the discussion of libraries is close to my heart. I totally agree with the point made or implied earlier that the existence of a part definition in…
  • Instructorman
    Instructorman over 10 years ago in reply to shabaz +2
    First off, I am impressed with the skill and attention to detail exhibited in your custom torroid library. Nicely done! Second, I appreciate the deep experience brought forward in this dicussion. The thoughts…
  • Instructorman
    Second, I appreciate the deep experience brought forward in this dicussion.  The thoughts expressed here are actually valueable in a real world context.
    shabaz over 10 years ago in reply to Instructorman
    Hi Mark,
    That toroid library was a pain ; ) it takes into account wire thickness, and ideal spacing to minimise capacitance between the turns.
    And I had forgotten so much trigonometry..
    I have a spreadsheet to calculate the number of turns based on desired inductance basically, and use that as input to the tool to auto-generate the part.
  • D_Hersey
    D_Hersey over 10 years ago
    Out of curiosity, Shabaz, can you do bifilar and trifilar windings with your scheme?  Can it handle xformers?
    shabaz over 10 years ago in reply to D_Hersey
    Hi Don!
    It can't, but that was next on the agenda. It should be easy to add that capability in terms of landing pattern, but knowing
    how to design it and how many twists is harder, most sources just state an empirical number. Even dielectric constant
    is guesswork when the wire manufacturers publish so little information : ( I've built some spreadsheets to do the calculations
    based on formulas I've found over the years, but have yet to try to measure any of it. I now have a VNA so can
    learn a bit more. I think (not sure) in the past most of this was done by careful experimentation for weeks/months until the transformers
    were 'just right', and a shame that experience is being lost to some extent perhaps.
  • D_Hersey
    That has been my experience, sometimes they come out consistent with the design eqs, often it is tweaking with metrology 'til the late hours.  I imagine the old-fashioned alternative, stuff like Pi wound coils, would have been an even bigger design nightmare, I cannot imagine modeling capacitance on a multi-layer, funkily wound coil.  Sometimes, they would make high-Q filters with them!  IIRC, we still don't even have formalisms for something like a Y-shaped core.  Nor, IIRC, do we even have a general formalism for capacitors.  We only have special cases, like parallel plate, or conductive sphere near conductive plane, or two spheres, cylinders.  Amazing that we are able to do so much when we are so ignorant.
  • D_Hersey
    'course the compute-intensive FEA method would not have been available in the old days as well.
    autodeskguest over 10 years ago in reply to D_Hersey
    No, but the principle was well-established. The reason we have the
    simpler forms for some of the special cases is that some very clever
    person looked at the FEA (he didn't call it that, but it's essentially
    where he started) and did some complex maths to figure out the result.
