EAGLE User Support (English) Whats happening with EagleCad & Cadsoft?
  • Replies 46 replies
  • Subscribers 181 subscribers
  • Views 3493 views
HI,
There have been plenty of user suggestions (including myself ) over the
years and many relating to the same old issues.
As a PAYING User, I have essentially invested my money ( but a lot of my
time) into using & Learning EagleCad.
So..
I would like to know ( from the horses mouth if possible) what is Cadsoft
Proposing/Planning for the next release(s) of Eagle Cad?
Is there an advantage to anyone ( especially users) if future features are
kept secret?
The following is what I can see as major changes in no particular order and
not inclusive..
Q1) Are there going to be any major changes to the LIBRARY?
Q2) Are we going to have a proper user definable /properly integrated BOM
window ?
Q3) Can CUT, COPY & PASTE ( and selection/group) work just like any other
application?
Q4) Can we open more than one PROJECT or LIBRARY part at the same time?
Will we be able to copy and paste ( Drag and drop) between these?
Q5) Can all the user settings and scr files ( or whatever setting files) be
kept in just ONE FILE , in one place and All accessible in ONE User
Preference (TABBED) window? (we can get rid of the Control panel if we do
this, and it means that updating Eaglecad will be less painful).
Q6) Are their any plans for some sort of SChematic/Layout hierarchy or
SUB-Circuits feature.
Q7) Any plans for a built in Gerber Viewer ( mac users have almost nothing
to work with here?)
Q8) Any plans for built in Circuit Simulation ( even basic stuff)?
Q9) Any plans for The Built in text editor to have its own Syntax
Highlighting etc?
Q10) Any plans for a built in Gerber Panalizer/Merger Tool?
Q11) Are there any plans for more control over pads/holes in the device
editor? i.e Odd/Complex shapes.
Q12) Can the design link feature work with other suppliers. ( should be
part of the BOM System anyhow)
Q13) Can we place less reliance on ULP's and command line entries as a
source of features/enhancements or usability, this should really be only
for specialised tasks. If you have a look at the ULP's over the years
theres a ton of them for Library Management and BOM'S  Is that telling you
something?
Q14) Can we have single keystroke functions for at lease basic items, Move,
Change Layer, etc ( user definable of course).
I just want to know whats happening, The Beta Test forum is VERY QUIET, The
last release only really had Farnell Shopping added/improved and a few bug
fix's, I am worried that development has either slowed down or stopped. OR
is their  something big in the pipeline. ( hoping!)
I am also worried that most suggestions are "Frowned" upon and this really
puts new users off !
So that I , ( and everyone else ) can stop wasting our time ( and your
time) with suggestions, can you please answer or give us something to look
forward to?
One reason I am asking all the above is that I am considering spending a
LOT OF TIME learning the scripting language so that I can program my own
features ( I have lots of big ideas) , Why, Because I don't know what is
the future for Eaglecad, And I am concerned that I may get to the stage of
writing very useful ULP's and then Cadsoft will release something in the
near future that replaces my work. Remember that all the time I spend
learning the scripting language TAKES ME AWAY From designing boards and
managing production, which is what brings in the money! and besides I
really pay cadsoft for the programming expertise.
At the end of the day I believe Eaglecad has a lot of potential, while I
can get boards designed ( its all there as far as capabilities are
concerned) I just think that there are too many frustrating / cumbersome
ways of doing things when I know there are easier /better ways.
The designing of a schematic or Layout or even designing a library part is
quite easy ( once you finally figure out the Eaglecad way) , and yes this
is the main parts of an application like this. The issues are with the way
it all comes together or integrates and is managed and how the user
interacts with it. As I have stated above  the key issues are Mainly
Project management, BOM Management, and especially Libray Management.
Thanks for listening .
Dave M
PS Please don't condemn me for asking.
    michaelkellett over 8 years ago in reply to linhtf +1
    You have replied to a six year old thread about a product that doesn't really exist any more - Eagle belongs to Autodesk and they are the people you need to ask about this. Start a new thread if you want…
    Former Member over 14 years ago in reply to kcadsoft
    >>Warren Brayshaw wrote:
    Klaus Schmidinger replied:
    >> For the through hole PAD this raises the question of the requested
    >> feature 'Pad stack'. Will there be Pad Stack functionality to
    >> specify pad dimension for the inner layers and  for each outer layer
    >> seperately, for a library package?  This part needs to ignore DRC
    >> restring settings. (likely only for the outer layers as internal
    >> layers will likely be meeting an 'internal layer standard' based on
    >> drill size).
    You will be able to draw wires and polygons for pads in any signal
    layer.
    Greetings
    Unfortuately your reply does not answer the question. "Pad Stack
    functionality--defining the pad diameter of any layer, singly"?
    I can interpret from what has been said:
    1) that we will be able to make odd shaped pads. Or more correctly add
    copper around a specified standard pad.
    2) this can be done on all signal layers
    3) an SMD pad can be virtually unliited in size (irrelevant for this
    discussion)
    Currently the restring diameter for all layers of a PTH pad is modified by
    the DRC setting. If the DRC setting is not to effect a single layer then the
    package pad setting will effect all layers.
    The DRC setting effects the whole board so any special cases must be taken
    care of in the definition of the package.
    For a custom part one may wish to set all layers to'as per library' or
    alternately custom the outer layers and have inner layers follow the DRC
    requirements for the board.
    So I feel the 'seed pad' diameter settings  need to exist for the outer
    layers and one for the inner layers.
    There are design cases where a large pad is needed on one side of a PCB but
    the other side needs the mnimum annulus, just enought to satisfy
    manufacturing for a PCB with through hole plating.
    For a double sided PCB it can be a requirement of no annulus around the hole
    on one outer layer, for voltage clearance reasons.
    I hope the above has ben considered in the implementation under development.
    Ragards
    Warren
  • kcadsoft
    kcadsoft over 14 years ago in reply to Former Member
    On 08/04/11 01:43, Warren Brayshaw wrote:
    Klaus Schmidinger wrote:
    >> ...............You will be able to draw wires and polygons for pads in any
    signal
    >> layer........................
    >> Klaus Schmidinger
    Hmmm! How will thermals and be applied when a pad/SMD has been enlarged to a
    custom shape?
    Will a polygon pour, on the board, keep away from and create thermals to the
    total custom shape or only the initial pad/SMD object?
    It will consider the total shape of the polygon used to
    enlarge the pad/smd. The polygon pour will keep away from the total
    custom shape, and will create thermals accordingly.
    Note that if you attach a wire to the pad in the package, that
    wire will not be subtracted from the polygon (of the same
    signal). It will be handled as if it had been drawn in the board.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
  • kcadsoft
    >>> drill size).
    >> layer.
    Greetings
    discussion)
    Time permitting, we are planning to make a long requested change
    to how the pad diameters are handled. Only pads that actually have
    a zero diameter will then be adjusted automatically to the design rules,
    and all others will have whatever diameter they are given. This, together
    with the possibility to draw copper polygons in a package to enlarge pads,
    should allow you to define pads of any shape and size.
    Klaus Schmidinger
    Former Member over 14 years ago in reply to Former Member
    On 7/28/2011 3:20 AM, Joern Paschedag wrote:
    The whole discussion about the hardware is childish.
    This newsgroup is about eagle. So please everyone take your stupid bla
    bla about hardware elsewhere.
    Joern,
    You bring a whole new meaning to "Mit freundlichen Grüßen."
    Martin K
  • linhtf
    linhtf over 8 years ago in reply to Former Member
    Hello Olin,
    Is there any chance to get your Eagle tools again? The download link on your website is unable to access.
    Start a new thread if you want to talk about Eagle.
