EAGLE User Support (English) Arbitrary Pad Shapes
  • Replies 12 replies
  • Views 1560 views
Last June, I posted about arbitrary pad shapes.  I was eventually able to
solve my problem and go to fab on my board.  There were 2 problems which
apply to the new issue I describe below.  One is line width and the other
is placement of the arbitrary pad shape on the final layout.
My new issue is I'm using a device which has through holes which are
basically rectangles with rounded corners.  I can create the hole using the
milling layer as described in the manual.  The problem (again) has to do
with the arbitrary pad shapes.
There are a couple of issues:
- In my previous post, the device was an SMT so a single pad wasn't a
problem.  But my board is 6 layers.  It seems (to me, a complete Eagle
novice) that this is a big deficiency in Eagle.  The reason is you need to
create the pad in each layer, making lots of work.  Another big problem
with this is the pad is not associated with the library part.  So if you
move the device, you need to move the pad in every layer you've built it.
Wouldn't it be better to build the pad in the library part itself and then
have Eagle place the pad in all the layers, as it does with "normal"
devices?
- Line width is still an issues.  It seems that since everything inside of
the lines of the pad are the pad itself, then zero width lines should be
allowed.  Then you could specify the outer limits of the pad, preventing
the pad from encroaching on other devices, without having to calculate how
far outside the line the pad goes, or whether the line width is going to
violate the design rules.
I expect that any responses to this will essentially be "Yeah, that's the
way it is.  Deal with it."  But any advice on how to make this easier would
be greatly appreciated.
Thanks!
Dave
    On 4/1/2013 12:29 PM, Dave Wills wrote:
    devices?
    I'm a little confused by the above. If you have a surface mount part
    then the SMD pad will only be on the top or the bottom it doesn't need
    to be drawn on the other layers.
    In the case of a through-hole pad, if you need a weird hole shape or a
    weird pad shape then you use the milling layer to make the whole shape
    and then use polygons to make the arbitrary pad shape on top and bottom
    that it. When the board house plates the the modified hole it will
    connect to whatever inner layers it's supposed to connect to, so you
    don't have to draw polygons on the inner layers.
    This is all handled in the library, nothing has to be done on the board.
    The pad will follow whenever you move the component, and keep in mind
    that I'm assuming V6 here.
    When defined in the library EAGLE will maintain the proper clearances
    without your intervention.
    Thanks!
    Dave
    Hi Dave,
    See my responses in line above. Let me know if there's anything else I
    can do for you.
    Best Regards,
    Jorge Garcia
    No thoughts on this?
    Dave
