Hello!
I've been finding that I really like the various paradigms in Eagle when it
comes to circuit design and PCB layout. The way eagle separates things
into parts libraries and the schematic editor are really good for me.
I'd like to get a standard version of Eagle, but I can really only justify
the cost to my boss if I can use it for our larger "NEMA4 style" (DIN Rail
components) enclosure designs as well as circuit boards.
The problem is that the board limited size in the Standard edition is no
where near the size of an enclosure.
I contacted CadSoft sales and they replied that I could use the document
layers in Eagles outside of the limits. Just no copper layers.
Ok..I thought I might be able to work with that until I tried to make a
simple terminal block and realized that I have no way of defining a pad or
a SMD position in the layout editor w/o defining something that would be in
a copper layer. Creating a "connection point" that has 2D physical
dimensions (Package) that I can layout AND associated with a connection
point in a schematic is the primary reason I wanted to use Eagle. Is there
a way to define connection points inside a 2D Package that does not consume
a copper layer?
What other software might I consider to do this? I was wowed by
SolidWork's Electrical, but it is priced prohibitvely high (and doesn't
even do PCBs).
Also EagleUP looks like a promising extension of wanting to document and
have layout plans for larger NEMA4 style enclosures.
Thank you for your time!
-Nickerbocker
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
