EAGLE User Support (English) Have a question about CadSoft EAGLE?  Ask our Expert, Jorge!
  • Replies 126 replies
  • Subscribers 200 subscribers
  • Views 10982 views
  • our
  • have
  • expert
  • eagle?
  • jorge!
  • ask
  • a
  • cadsoft
  • about
  • question
Jorge_Garcia
Jorge_Garcia over 13 years ago
If you have questions about CadSoft EAGLE, please click here to post your question!
If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Jorge Garcia
I'm a young engineer with extensive experience working on EAGLE. My interests include Power Supply design and LED solid state lighting, and I'm always impressed by a well designed PCB.
If not already, you'll need to
image or image
to ask your question.
Otherwise, click reply below.
    Hi im helping a university lecturer to ask few question here.
    she got a PCB Milling Machine from a taiwan company, but she cannot get the correct gerber file to drill the pcb.is it eagle able to do that?
    she current using free version, but she claim that she unable to generate the gerber file from the trial version., is it full version will unlock this feature?
    do you have any sample gerber file that i can give to her to do a test?
    regard
    isaac
    e14 Contributor over 12 years ago in reply to autodeskguest
    Thank you. This does help.
    autodeskguest over 12 years ago in reply to tonyo
    On 11/6/2013 2:21 PM, Tony Ozrelic wrote:
    hi,
    i'm looking for a way to highlight a net or a part in the schematic
    window and have the same net or part highlighted in the PCB layout
    window.
    The idea here is that I would like to visually confirm that all parts
    and nets on the schematic are also on the board.
    Hi Tony,
    I can understand that initially you'll want to do that but with time
    you'll be able to rely on EAGLE's F/B annotation.
    Ideally you would want a dual monitor setup, but most don't have that.
    What you do then is show both editors on the same screen, resize the
    windows so that they share the monitor equally. Now if you activate the
    show command on the schematic you can click on the various nets and see
    them light up on the board.
    hth,
    Jorge Garcia
  • tonyo
    tonyo over 12 years ago
    hi,
    i'm looking for a way to highlight a net or a part in the schematic window and have the same net or part highlighted in the PCB layout window.
    The idea here is that I would like to visually confirm that all parts and nets on the schematic are also on the board.
    is there a way to do this?
    thanks,
    tonyo
    autodeskguest over 12 years ago in reply to e14 Contributor
    On 11/5/2013 5:41 PM, Elliott L wrote:
    My question lays in the autorouting and/or wiring algorithm. Can you
    describe for me, in great detail, how the autorouting system works?
    Where is the file that handles this? How does the entire EAGLE program
    determine the best/shortest route to lay wires?
    Hi Elliott,
    In a nutshell, EAGLE's autorouter is a grid-based router. Its splits up
    your board area based on the routing grid and proceeds to route until it
    runs into a roadblock. At that point it will ripup a certain number of
    already routed tracks defined by mnRipupLevel. It then starts to route
    again. Section 7.7 of the manual describes this process in detail.
    From this simple description you can infer that EAGLE isn't concerned
    with best or shortest path, it's just trying to get everything
    connected. By adjusting certain cost factors you can guide it to seek
    the shortest paths, but there's no guarantee that it will.
    You can load and save various cost configurations for the autorouter,
    but the actual code is within the EAGLE executable.
    hth,
    Jorge Garcia
    Cadsoft Support
  • Olin
    Olin over 12 years ago in reply to billkru
    I need to be able to orient the LED cathodes so that they are all pointing radially inward.
    Use the R option to specify orientation.
  • billkru
    billkru over 12 years ago in reply to autodeskguest
    Thank you Lorenz.  I'd suspected that scripting had a limit I was encountering.  Looks like I'll have to research ULP.
    autodeskguest over 12 years ago in reply to billkru
    Bill Krueger wrote:
    Thanks, I am aware of the various co-ordinate system options in eagle
    and I am using polar co-ordinates. My script already does exactly what
    you describe.  Using polar co-ordinates, the script moves the device and
    places the LEDs on a circle or radius r and angle theta  ..., and
    rotates the device.  That part works just fine.
    However, this doesn't answer the question I'm asking. Let's assume that
    pin 1 of the LED package I want to place is the cathode & pin 2 is the
    anode.  What I also need to guarantee is that pin 1, the cathode,
    points radially inward +once the device is already placed and rotated
    correctly+.
    As I mentioned, I can pre-orient all the LEDs in an unused area by
    pointing all the cathodes in one direction and then run the script.
    Eagle is consistent in the way it places the LEDs on the board once
    that's done.  However, if I don't orient all the LEDs cathode
    orientation consistently before running the script, Eagle will orient
    some of the LEDs with cathodes pointing inward and some with cathodes
    point outward depending on the cathode orientation before I ran the
    script.  So I do have away around this issue, but I was hoping for
    something that didn't require manual tweaking before running the script.
    What I'm asking is there a way to guarantee the cathode/anode
    orientation using a script command?  I wasn't able to find anything in
    the documentation that describes how that might be done via a script.
    scripts are not able to access data from the board.
    For that you need an ULP.
    Lorenz
  • billkru
    Thanks, I am aware of the various co-ordinate system options in eagle and I am using polar co-ordinates. My script already does exactly what you describe.  Using polar co-ordinates, the script moves the device and places the LEDs on a circle or radius r and angle theta  ..., and rotates the device.  That part works just fine.
    However, this doesn't answer the question I'm asking. Let's assume that pin 1 of the LED package I want to place is the cathode & pin 2 is the anode.  What I also need to guarantee is that pin 1, the cathode, points radially inward once the device is already placed and rotated correctly.
    As I mentioned, I can pre-orient all the LEDs in an unused area by pointing all the cathodes in one direction and then run the script.  Eagle is consistent in the way it places the LEDs on the board once that's done.  However, if I don't orient all the LEDs cathode orientation consistently before running the script, Eagle will orient some of the LEDs with cathodes pointing inward and some with cathodes point outward depending on the cathode orientation before I ran the script.  So I do have away around this issue, but I was hoping for something that didn't require manual tweaking before running the script.
    What I'm asking is there a way to guarantee the cathode/anode orientation using a script command?  I wasn't able to find anything in the documentation that describes how that might be done via a script.
    Bill Krueger wrote:
    I'm doing a layout that has a circular array of LEDs packed tightly
    together in an approximately 320 degree circle.  Based on the size of
    the board (really small) and the number of LEDs (really large), there is
    a need for precision device placement.  I use a script to place the LEDs
    exactly where they need to be.  All the LEDs origins are centered on a
    circle.  I've got the syntax for device placement, radial orientation,
    and rotation mastered.
    you are aware of the posibility to use polar coordinates and/or
    relative coordinates (online_help/Editor_Commands/Command_Syntax)?
    The script works fine for placing the LEDs in their appropriate position
    and that hasn't presented a problem.However, there's one thing that I
    have not been able to discover by reading the Eagle documentation nor by
    experimentation.  I need to be able to orient the LED cathodes so that
    they are all pointing radially inward.  Is there any way to force device
    orientation (i.e. make certain that it's the LED cathodes and not the
    anodes that point radially inward) based on pad or pin name or some
    other attribute?
    I've been able to accomplish this by "pre-orienting" all the LEDs on an
    unrouted area of the board and then run the script.  What I mean by this
    is that I'll manually move all the LEDs to some arbitrary area of the
    board and orient them so that their cathodes all point to the right and
    then run the script.  The script places the LEDs exactly where they need
    to be with the desired cathode orientation.  If I flipped the LEDs so
    that the cathodes all pointed left during my "pre-orienting", the
    cathodes all wind up facing radially outward.  So, the device placement
    rules are at least consistent.  However, this is a pretty kludgy way to
    accomplish something I'd like to be able to do entirely via script.
    rotating parts can be accomplished using the rotate command.
         mark (center_x center_y)
         move part_name (P radius angle)
         rotate angle part_name
    (see online_help/Editor_Commands/Command_Syntax, ../mark, ../move,
    ../rotate, ../add )
    Lorenz
