EAGLE User Support (English) Have a question about CadSoft EAGLE?  Ask our Expert, Jorge!
  • Replies 126 replies
  • Subscribers 192 subscribers
  • Views 8190 views
  • our
  • have
  • expert
  • eagle?
  • jorge!
  • ask
  • a
  • cadsoft
  • about
  • question
Jorge_Garcia
Jorge_Garcia over 12 years ago
If you have questions about CadSoft EAGLE, please click here to post your question!
If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Jorge Garcia
I'm a young engineer with extensive experience working on EAGLE. My interests include Power Supply design and LED solid state lighting, and I'm always impressed by a well designed PCB.
If not already, you'll need to
image or image
to ask your question.
Otherwise, click reply below.
  • Olin
    Olin over 12 years ago in reply to billkru
    I need to be able to orient the LED cathodes so that they are all pointing radially inward.
    Use the R option to specify orientation.
    autodeskguest over 12 years ago in reply to Former Member
    On 11/5/2013 5:41 PM, Elliott L wrote:
    My question lays in the autorouting and/or wiring algorithm. Can you
    describe for me, in great detail, how the autorouting system works?
    Where is the file that handles this? How does the entire EAGLE program
    determine the best/shortest route to lay wires?
    Hi Elliott,
    In a nutshell, EAGLE's autorouter is a grid-based router. Its splits up
    your board area based on the routing grid and proceeds to route until it
    runs into a roadblock. At that point it will ripup a certain number of
    already routed tracks defined by mnRipupLevel. It then starts to route
    again. Section 7.7 of the manual describes this process in detail.
    From this simple description you can infer that EAGLE isn't concerned
    with best or shortest path, it's just trying to get everything
    connected. By adjusting certain cost factors you can guide it to seek
    the shortest paths, but there's no guarantee that it will.
    You can load and save various cost configurations for the autorouter,
    but the actual code is within the EAGLE executable.
    hth,
    Jorge Garcia
    Cadsoft Support
  • tonyo
    tonyo over 12 years ago
    hi,
    i'm looking for a way to highlight a net or a part in the schematic window and have the same net or part highlighted in the PCB layout window.
    The idea here is that I would like to visually confirm that all parts and nets on the schematic are also on the board.
    is there a way to do this?
    thanks,
    tonyo
    autodeskguest over 12 years ago in reply to tonyo
    On 11/6/2013 2:21 PM, Tony Ozrelic wrote:
    hi,
    window.
    Hi Tony,
    I can understand that initially you'll want to do that but with time
    you'll be able to rely on EAGLE's F/B annotation.
    Ideally you would want a dual monitor setup, but most don't have that.
    What you do then is show both editors on the same screen, resize the
    windows so that they share the monitor equally. Now if you activate the
    show command on the schematic you can click on the various nets and see
    them light up on the board.
    hth,
    Jorge Garcia
    Former Member over 12 years ago in reply to autodeskguest
    Thank you. This does help.
    Hi im helping a university lecturer to ask few question here.
    she got a PCB Milling Machine from a taiwan company, but she cannot get the correct gerber file to drill the pcb.is it eagle able to do that?
    she current using free version, but she claim that she unable to generate the gerber file from the trial version., is it full version will unlock this feature?
    do you have any sample gerber file that i can give to her to do a test?
    regard
    isaac
    Hi Isaac,
    The free version of EAGLE can generate gerbers, so it's likely that she
    is either generating the gerber files incorrectly or that the machine
    expects some other format.Chp 9 of the EAGLE manual details making gerbers.
    In a nutshell here's the procedure:
    1. Open the board layout
    2. Click on the CAM processor
    3. File -> Open -> Job within the CAM processor window
    4. Select the appropriate CAM job (gerb274x.cam is for 2 layers
    components on top only, gerb274x-4layer.cam is for 4 layers components
    on both sides).
    5. Click Process Job
    6. For drill file, repeat step 3.
    7. Select Excellon.cam
    8. Repeat step 5
    I would recommend that you look carefully at the type of files the
    machine accepts and then go from there. I don't have much experience
    with Milling machines myself, but I know there are many users that make
    PCBs in this manner. Perhaps one of them will chime in.
    Best Regards,
    Jorge Garcia
    autodeskguest over 12 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    (...] but I know there are many users that make
    possibly not with this generic "Have a question about CadSoft EAGLE?
    Ask our Expert" subject.
    At least in my newsreader they all end up in one gigantic thread.
    Lorenz
    I got a feedback from them,He had told me that the machine only read the drill files in the following format:
    .txt
    .drl
    .apr
    .tap
    The one from Eagle is .drd though.
    can you help me to check is it possible eagle can generate . txt, drl, apr or tap file?
  • dukepro
    dukepro over 12 years ago in reply to Former Member
    On 11/11/2013 06:53 AM, Isaac Tan wrote:
    txt
    drl
    apr
    tap
    apr or tap file?
    Have you tried drillcfg.ulp?
        - Chuck
