EAGLE User Support (English) Looking for FH12-40S-0.5SVA Eagle Footprint
  • Subscribers 180 subscribers
  • Views 865 views
  • connectors
  • footprint
  • ffc
joeystrandnes
joeystrandnes over 8 years ago
Hi everybody!
So I’m having trouble finding a footprint for the SVA version of the FFC socket "FH12-40S-0.5SVA", I’ve looked every ware and I can’t find the version I’m looking for.
I’m terrible at making footprints and I’d probably mess it up if I made it.
Thanks in advanced!
    0 genebren over 8 years ago
    Joey,
    You might want to try con-hirose.lbr.  I am using version 7.6 and I see the connector you are looking for in there.
    Good luck,
    Gene
  • joeystrandnes
    0 joeystrandnes over 8 years ago in reply to genebren
    I’m not sure what version I have but I can’t find the "SVA" version of the socket, the only sockets available are the "SH" versions.
    0 genebren over 8 years ago in reply to joeystrandnes
    Yes, you are correct.  I did notice that there is a library element for the FH12-60S-0.5SV part. You might be able to copy this part and cut it down a bit.  I have had pretty good luck with that approach.
    Gene
    Joey,
    I also just noticed that the Hirose library, available on this site has an entry for a FH12-40S-0.55SV(55).  Not a 100% sure that this is same connector, but it does look very close.  On the AutoDesk Eagle page there are several libraries featured, plus a 'more libraries' button. Click on the button to find the Hirose library.
    Gene
  • joeystrandnes
    I’m not sure that will work. The reason being that the SV footprint and SVA footprint aren’t similar enough.
    I think I might have to make my own...
  • joeystrandnes
    So i made my own, hopefully it will work!
    Here is the link to it if anybody is interested!  https://1drv.ms/u/s!AgCPzhmRXVnFiGBRIJ1ATVONtQLY
