EAGLE User Support (English) Problems building tslib for BB-View_4.3
  • Replies 16 replies
  • Subscribers 179 subscribers
  • Views 1191 views
A few months ago I purchased a BB-View_4.3 display with touch screen. My goal is to setup a
cross development environment and learn how to create Qt app's for my BBB.  At this point
I'm about 98% of the way there.  I can create app's and have them shows up on my display.
I can use a USB mouse to interface to my app, but I can't get the touch screen to work.
The issue as far as I can see is with the building of the tslib library.  I followed the
build procedures outlined on http://embedded.von-kannen.net/ site.  Everything seemed to
work except it won't produce a tslib.so file.  If you look in the build directory, a tslib.o
object file is produced which wouldn't happen if there was an error.
I also looked in the tsmake.txt file which looks like a build output file.  In the file I
see the creation of "libts.so", "touchkit.so" and other assorted libs but not tslib and no
error messages, there are warnings but no errors.
What am I missing?? Is the build procedure on the above site correct?? I'm at a loss.
  • tomaja
    0 tomaja over 10 years ago
    So, you don't have it under ~/qt-bbb/tslib/lib ?
    I also followed those steps and have it there. It's a symbolic link to libts-1.0.so.0.0.0 in the same directory
    Dragan
  • tomaja
    One more thing, since you use the same screen image
    Apart from that build issue, did you have any other issues with this screen?
    I have pointer "jitter" problem most of the time. Mouse pointer jumps to the right of the screen by itself, and it happens more if something white/light is displayed on the screen.
    Dragan
    0 Former Member over 10 years ago in reply to tomaja
    In my ~/qt-bbb/tslib/lib I have libts-1.0.so.0.0.0 and a couple of other similarly named files.  There is one file that is named tslib with no extension. It's about 6.7K in size.  At the risk of sounding like the dullest knife in the drawer, Is that what I'm looking for??
    As far as the mouse pointer is concerned, it's not smooth at all.  I was just happy to get it functioning and would try and take care of that later.
  • tomaja
    0 tomaja over 10 years ago in reply to Former Member
    Here's what I have there:
    tomaja@dragan-bbb-builder:~/qt-bbb/tslib/lib$ ls -la
    total 32
    drwxrwxr-x 4 tomaja tomaja  4096 јан  7 01:17 .
    drwxrwxr-x 6 tomaja tomaja  4096 јан  7 01:17 ..
    lrwxrwxrwx 1 tomaja tomaja    18 јан  7 01:17 libts-1.0.so.0 -> libts-1.0.so.0.0.0
    -rwxr-xr-x 1 tomaja tomaja 10346 јан  7 01:17 libts-1.0.so.0.0.0
    -rwxr-xr-x 1 tomaja tomaja   952 јан  7 01:17 libts.la
    lrwxrwxrwx 1 tomaja tomaja    18 јан  7 01:17 libts.so -> libts-1.0.so.0.0.0
    drwxrwxr-x 2 tomaja tomaja  4096 јан  7 01:17 pkgconfig
    drwxrwxr-x 2 tomaja tomaja  4096 јан  7 01:17 ts
    Please note the libts.so symlink pointing to libts-1.0.so.0.0.0 (this is your dynamic library, compare the size to make sure it's OK).
    You can also check the file to make sure it's a valid armeabi binary like this:
    tomaja@dragan-bbb-builder:~/qt-bbb/tslib/lib$ file libts-1.0.so.0.0.0
    libts-1.0.so.0.0.0: ELF 32-bit LSB  shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, BuildID[sha1]=b6d880a5773ccaafd6a5204f4983a8bac1ef80d1, not stripped
    If you just don't have that symbolic link but you have the library you can create the link on your own like this:
    ln -s libts-1.0.so.0.0.0 libts.so
    I hope this helps,
    Dragan
  • tomaja
    One more thing, are you sure you also executed
    make install
    when you built tslib?
    If you are not sure, you can run it now in ~/qt-bbb/downloads/tslib
    Dragan
    Ok, I have almost everything you have.
    drwxrwxr-x 4 mark mark  4096 Jan  8 08:22 .
    drwxrwxr-x 6 mark mark  4096 Oct 23 14:17 ..
    lrwxrwxrwx 1 mark mark    18 Jan  8 08:13 libts-1.0.so.0 -> libts-1.0.so.0.0.0
    -rwxr-xr-x 1 mark mark 10330 Jan  8 08:13 libts-1.0.so.0.0.0
    -rwxr-xr-x 1 mark mark   950 Jan  8 08:13 libts.la
    lrwxrwxrwx 1 mark mark    18 Jan  8 08:13 libts.so -> libts-1.0.so.0.0.0
    drwxrwxr-x 2 mark mark  4096 Jan  8 08:13 pkgconfig
    drwxrwxr-x 2 mark mark  4096 Jan  8 08:13 ts
    mark@mark-VirtualBox:~/qt-bbb/tslib/lib$ file libts-1.0.so.0.0.0
    libts-1.0.so.0.0.0: ELF 32-bit LSB  shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, BuildID[sha1]=918f60404cfe15eb566503d3e6c66b1bc4dc612b, not stripped
    I re-ran the make install but I still can't find the tslib.so file.
    I guess I'm a little confused, libts-1.0.so.0.0.0 is the actual library file and tslib.so is an intermediate link file?
  • tomaja
    Hi Mark, thanks for replying.
    I see just now that you're looking for tslib.so and not libts.so. Is that right, or just a typo?
    As for the libts.so, I see that you have it in line 6 of your ls command output.
    No, libts.so is the Symbolic link - Wikipedia, the free encyclopedia. This is just a kind of a shortcut file (it's somewhat similar to shortcuts on Windows if you're more familiar with them) .
    Dragan
    Hi Dragan,
    My apologies for not being clearer.  Yes, that is correct I'm looking for tslib.so.
  • tomaja
    Mark,
    I'm not sure such a library file is being built. Where did you find that you need to have it?
    AFAIK, touch screen library .so is called libts.so (this is standard library naming convention, check 3.1.1 here -> Shared Libraries).
    Dragan
    Hi Dragan,
    I guess I wrongly assumed that tslib.so was the name of the lib being produced by the build.  Thanks for the article, I'll dig into that.
    So, libts.so contains all of the methods listed in tslib.h??   I now realize that it's a convention but you can see my confusion.
    When I originally tried to run ts_calibrate on my beaglebone it complained that it couldn't find things like ts_open, etc.  If the actual lib
    I need is libts.so then maybe it was some environment variables not being set correctly. I'll try again.
