    • Avnet Boards Community
EAGLE User Support (English) IDF export broken?
  • Replies 18 replies
  • Subscribers 176 subscribers
  • Views 2882 views
  • idf
  • export
IDF export broken?
Joop14
Joop14 over 10 years ago
Dear Cadsoft,
I have some questions about your generate-3d-idf-data.ulp.
According to your document $EAGLEDIR/doc/ulp/generate-3d-idf-data_en.pdf the height of a package is drawn in layers 57 and 58. The board in layer 50.
How do I create these layers?
I patched the ulp by changing layers to 150, 157 and 158. This way I'm able to create the layers and draw the contour of the height of the part.
Why isn't it possible to create layers 50, 57 and 58?
Thanks for answering,
Joop
    0 autodeskguest over 10 years ago in reply to Joop14
    And this is the exact problem. How can you expect the contour of an
    object to be correct while using, for example, the keepout layer to
    guess the dimension of a package???
    This has been brought up before, the ULP will be improved to be able to
    ignore the keepout layers in the XY calculation.
    The old, patched ULP is included in the attached file.
    Thanks for this, I'll make sure it gets added to the main release of
    EAGLE. Thank you again for bringing this up.
    Best Regards,
    Jorge Garcia
  • Joop14
    0 Joop14 over 10 years ago in reply to Joop14
    Dear Cadsoft team,
    Because there's almost one week passed since my last posting, do you have any thoughts about this?
    Kind Regards,
    Joop
    On 7/15/2015 8:18 AM, Joop14 wrote:
    Dear Cadsoft team,
    Hi Joop,
    I did respond, I thanked you for the correction, stating that it will be
    included in the next release of EAGLE for everyone's benefit and
    informed you that the eagleidfexporter.ulp was going to be adjusted to
    not include the keep out layers in the calculation.
    I apologize if I missed a question in the last exchange.
    Let me know if you don't see it or if it didn't make it to you.
    Best Regards,
    Jorge Garcia
  • Jorge_Garcia
    0 Jorge_Garcia over 10 years ago in reply to Joop14
    I just came  now to element14 and my original response isnt here. great
  • Joop14
    0 Joop14 over 10 years ago in reply to Jorge_Garcia
    Hello Jorge,
    Thank you for coming back.
    Yes, I believe there is an issue with this board that sometimes a new post does not show up or only after a couple of days...
    I believe that, whatever existing layer you choose to calculate the dimension of a package, it's never going to work. At least not accurately.
    Imho the only good solution is to use the old (patched) ulp that makes use of a new additional layer that contains a 2d geometry
    of the package and where the linewidth of that layer is used to calculate the height. (height is linewidth x 1000)
    Anyway, thank you for looking into it.
    Kind Regards,
    Joop
  • Joop14
    0 Joop14 over 9 years ago
    Dear Cadsoft team,
    I found another bug in your IDF export.
    Parts placed on the bottom were not mirrored correctly.
    Please find attached the corrected ulp v2.1.
    One other thing, why is Cadsoft still shipping with the broken IDF export v1.9?
    (for example see V7.4.2 beta)
    Kind Regards,
    Joop
    8154.generate-3d-idf-data.ulp.tar.gz
  • Joop14
    There's a problem with this board.
    Sometimes a new reply does not bump up the thread.
  • Jorge_Garcia
    0 Jorge_Garcia over 9 years ago in reply to Joop14
    Hi Joop,
    I hope you're doing well. Long story, here's where we are at. The devs don't want the layers changed so I altered the ULP to check for the correct layers 50,57,58(correct being defined by the devs) and if they are not found then the ULP offers to create them. I've taken your latest changes and incorporated them along with my changes to make V2.2 of the ULP. If you can send me the file that exercises the mirror bug, I would appreciate it to make sure the merged ULP is working. Once that's done then I can send it to the devs so that it can be included in the next release of EAGLE.
    You can e-mail me support@cadsoftusa.com.
    Best Regards,
    Jorge Garcia
