EAGLE User Support (English) Bug, Breaking a polygon (7.5.3)
  • Replies 16 replies
  • Subscribers 187 subscribers
  • Views 1738 views
With this code I am able to break a polygon.
Im using SET CONTEXT to make a "move polygon" function.
First, I attach the function to the wire object like this:
| SET CONTEXT wire 'Move polygon' 'run polygonmove.ulp';
At the ulp, I check if a polygon wire is grouped with this code:
|board(B) B.signals(S) S.polygons(P) if(ingroup(P))
This works. But the polygon parent of the grouped wire is not completely
grouped, hence I have to help out a bit with this:
| setgroup(P); //(**)
This doesnt seem to set all the wires in the group, cause when I do:
| sprintf(tmpstr,"move (>@)");
| exit(tmpstr);
The polygon breaks up. The selected wire doesnt follow the move, only
the other wires.
I tried different clrgroup before the setgroup first, like
| P.wires(W) clrgroup(W);
or
| clrgroup(P)
or even
| clrgroup(B)
But they don't seem to help.
(**) If I play around with setgroup(P,1), the polygon REALLY gets messed
up, but the originally selected wire of the polygon is still ungrouped.
I assume this is a bug, but are there any workarounds?
    | setgroup(P); //(**)
    | exit(tmpstr);
    the other wires.
    or
    | clrgroup(P)
    or even
    | clrgroup(B)
    Can someone from Cadsoft confirm this bug? I also want to stress there
    is not a 100% workaround found yet.
    | setgroup(P); //(**)
    | exit(tmpstr);
    the other wires.
    or
    | clrgroup(P)
    or even
    | clrgroup(B)
    autodeskguest over 10 years ago in reply to autodeskguest
    On 20.04.2016 21:46, warrenbrayshaw wrote:
    Also, I feel a polygon should should be one of the selectable objects
    for SET CONTEXT
    I agree on this. Initially I was looking for that, but had to settle
    through wire. The "board(B) B.signals(S) S.polygons(P) if(ingroup(P))"
    does work around it.
    I also think the wire object should be brd/sch context specific, like
    "brd.wire" and "sch.wire" being two different context objects. Right
    now, I have to do "edit .sch/.brd;SET CONTEXT wire ..." to create
    different context menus for the two.
    There may be more objects that needs it, but since I don't have an
    overview atm, Im not ready to post to suggestion forum yet, but I
    believe Cadsoft will read this anyway.
    On 20/04/2016 7:04 p.m., Morten Leikvoll wrote:
    On 19.04.2016 21:58, warrenbrayshaw wrote:
    Hi Morten
    set Option.RepositionMouseCursorAfterContextMenu  1;
    polygonmove.ulp contains
    exit("move (>c@)");
    Right click on the polygon wire
    Select from the context menu 'Move polygon'
    Polygon is now stuck to mouse
    Well, for some reason this doesnt work with my installation (7.5.3)..
    Nothing gets moved. I need to do this:
         setgroup(P);
         exit("move (>c@)");
    ... and the polygon except the selected wire follows the mouse. Its like
    if the setgroup toggles the group flag of the polygon.
    I get the same result on 7.5.0.
    Hi Morten
    Apologies, It seems I made an error as I cannot get it to work today.
    There definitely is some repair work need in this area by Cadsoft
    Once those polygons are dragged apart and you follow that with a
    ratsnest it fills a polygon that is not where the wires are. There is
    odd behaviour in setgroup() that needs clarifying.
    for SET CONTEXT
    I may have found a workaround.
    See if the following ULP works for you. It tests if the wire you select
    is part of a polygon. If so, exits grouping the object where the cursor
    is and then moves that object, Hopefully its still the polygon edge you
    started from.
    if(board) board(B){
       B.signals(S){
         S.polygons(P){
           if(ingroup(P)){
             exit("group (c@);move (>c@)");
    Hi Morten
    exit("move (>c@)");
         setgroup(P);
         exit("move (>c@)");
    Hi Morten
    exit("move (>c@)");
    HTH
    Warren
