EAGLE User Support (English) .4mm to 2.54mm Routing
  • Replies 17 replies
  • Subscribers 180 subscribers
  • Views 1549 views
I seem to be having a heck of a time getting the autorouter to route
between .4mm pitch 48 pin qfn smd and 2 x 2.54mm pth header strips.
https://dl.dropboxusercontent.com/u/2238318/esp32hb.zip
Any suggestions?
Glenn
    autodeskguest over 9 years ago +1
    Hi! You can't manually route to/from the QFN48 as well. Just run a DRC on the unrouted board and you'll get a ton of errors. The package already violates the minimum clearance rules. So the autorouter…
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    rk wrote on Sat, 17 September 2016 11:36
    violates the minimum clearance rules. So the autorouter can't reach the
    SMDs without violating the rules even further, hence it leaves them out.
    Oh yes.... I'm slightly embarrassed about not spotting that before putting
    up my post! In my defence I was more focussed on my autorouter dying and
    EAGLE exiting every 30 seconds!
    Maybe a slight usability improvement they could make to EAGLE would be to
    have an autorouter report which it generated when it was complete which
    specified why it hadn't routed the nets which were remaining unrouted? I
    have to admit I almost never use the autorouter and when I have I've never
    seen this problem so maybe it does give this info already, but for me it
    just goes to a certain percentage and says its finished when clearly there
    was still loads to do. Maybe if it said something like "Complete: 20%
    routed, 80% unrouted (70% design rule violations, 10% no routing path
    found)" that might be more helpful than just saying "complete".
    Still, I should have thought about running DRC though.....
    Best Regards,
    Rachael
    autodeskguest over 9 years ago in reply to rachaelp
    Am 17.09.2016 um 12:56 schrieb Rachael:
    Even when not using the autorouter, you should always run the DRC
    before doing any routing. Just to see that there is no hidden error
    (dimension, keepout, ...). This is especially true when you are 100%
    sure that there is no error, just let the DRC print that out.
    As I am doing things wrong more often than not, this approach saved me
    quite some time, actually.  image
    Rene
    Rene
  • rachaelp
    Absolutely! In my normal design flow the DRC first run will happen as soon as I create my board and load the appropriate DRC settings and I'll run DRC again any time any significant changes are made.
    I was afraid you were going to say that
    Why afraid? Manual routing - particularly of localised bits - is a lot
    easier than setting up the autorouting rules!
    I agree, manually routing for the most part is much simpler, the autorouter isn't good enough or stable enough to be used for full on routing. For me I can cause it to abruptly exit within minutes of starting to use it, that's just not an acceptable level of stability for me.
    Back to the OP's question, I have downloaded the design and have confirmed that for no obvious reason it just won't route from the QFN to anywhere else. I don't know if this is something odd in the library part (I had a look but couldn't see anything) or something relating to the grid, etc. I couldn't see anything on keepout/restrict layers. Unfortunately I can't keep the autorouter open for long enough without crashing for me to do any in depth analysis of why it is not working.
    Manual routing of this is simple though if you rotate the IC by 45 degrees and move it down slightly and then all of the signals just flow nicely out to the connectors so not using the autorouter shouldn't be a big problem.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/205878
    Hi Rachel, thanks for checking this for me.
    I use autorouting mostly for rough placement scenarios and sometimes for
    lazy simple routing like this.
    I did not created this library but did add an extra symbol and moved the
    pads on the footprint slightly as they were not lining up with the pad
    centers on .2mm grid spacing (which I thought was the original issue
    with it not routing) but it did not help.
    https://dl.dropboxusercontent.com/u/2238318/esp32.lbr
    Glenn
    On 9/17/2016 6:36 AM, René König wrote:
    Hi!
    So, to solve the problem, first check the DRC parameters. Then go to the
    schematic and check the CLASS settings. Finally, ensure that the NETs
    attached to ESP32 belong to the proper CLASS.
    Rene
    Thanks René
    for me.
    Best Regards,
    Rachael
    Glenn
    Hi Rachel,
    As Rene, indicated it was my default routing class specs that caused the
    routing not to work.
    Thanks for your help
    Glenn
