Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51464 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
    Hello
    1.is there ulp or command for copy my board outline from layer 20 (dimension ??) to other layers (29 30) or or if no how do make this ??
    2. is posible to run cam job from script or ulp ??
    3. how ot copy one board to another ?? is it poisble by script or ??
    Thx for answer and sorry bad english :-D Jan Kolář
  • Richard_H
    Richard_H over 15 years ago in reply to JesperR
    Hi Jesper,
    use CTRL + left mouse button with the ROUTE command to start your routing at any position on a wire or a via.
    Richard
  • JesperR
    JesperR over 15 years ago
    Richard,
    I have been working with eagle for about a year now  and one thing is bugging me. when designing a pcb i wanted to connect  two traces of the same net. the airwire is where the traces come closest  to each other but i want to route it from a different place on one of  the traces.
    for example:
    http://img638.imageshack.us/i/eagleknipsel.jpg/
    if  i want to rouet directly from R1 to R2 i cant do that with the ROUTE  tool because it will only start from where the airwire starts. i now do  that piece by using WIRE tool, how ever that doesnt highlite the traces  and it doesnt snap to the exact position of a pad. is there a better way  to route directly from R1 to R2 ?
    Jesper
    EDIT:
    i have found my answer. by using ctrl when clicking it will start at that pad.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    Hi Allen,
    to start a new discussion, click onto the Discussions link on top of this page.
    Home >                   Design Tools >                   CadSoft EAGLE >             Discussions
    Then you find Start a Discussion in the Actions box on the right hand side.
    CadSoft has an office in Florida:
    CadSoft Computer
    19620 Pines Blvd. Suite 217
    Pembroke Pines, FL 33029
    Phone: 954-237-0932,     Fax: 954-237-0968
    URL: www.cadsoftusa.com
    Richard
    e14 Contributor over 15 years ago in reply to Richard_H
    Richard,  This is my first post on to your site.    ?;  where do I find the ? window other than what I just did by clicking on 'reply' in one of your
    current postings?
    Anyway, I needed a test posting to see how my post is viewed in the general public window.
    Is CadSoft still physically located in Florida?   I had not heard from CS activities for a long while until I received the new brochure from E14.
    Thanks for being here.
  • spcmicro
    spcmicro over 15 years ago in reply to Richard_H
    Thank you Richard. That seems to work fine.
  • Richard_H
    Richard_H over 15 years ago in reply to spcmicro
    Hi Steve,
    when you are ROUTEing the signal and you want to set a via at the end of the trace use Shift + left mouse button. EAGLE automatically places a via then.
    Richard
  • spcmicro
    Hello Richard,
    I have a basic question regarding routing multi layer boards. This is my first 4 layer board and I have set up layers 2 and 15 as the inner layers. One is $VCC and the other is $GND. I have outlined the plane fill area on both innner layers. My question is this: When I am manually routing a trace and I want to connect to an inner layer I can't figure out how to do it and I can't find it described anywhere in the documentation. I have tried routing the signal to an open area on the board and then selecting the desired layer, such as $GND, and when I click it just ends the trace without a via on leaves the airwire connected to that spot. I know I'm missing something basic here. Thanks in advance for your help.
    Steve... .. .
  • Richard_H
    Richard_H over 15 years ago in reply to auspoundy
    drill-aid.ulp is no longer neccessary. The EPS device draws the pads with a defined hole diameter. IMHO the line
       "      /d  5000 def\n  %% But override it to 0.5mm\n"\
    defines the diameter of the opening in the pad.
    Richard
  • auspoundy
    auspoundy over 15 years ago in reply to Richard_H
    Thanks Richard, perfect.  I added these to the DEF file, changed my CAM job to use the modified driver, and my output PS file now has the drill holes.  Does this negate the need to use the drill-aid?  I tested it out and it seems that even after I've taken the drill layer 116 off, I get the modified holes. Is there a way (or a need??) to specify the drill hole equivalent that the drill-aid script did?
