Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51490 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • Richard_H
    Richard_H over 15 years ago in reply to weuns
    before you installed EAGLE 5.10 you have got the license information from us. You had this to download from the CadSoft website. It was a file named "serialnumber".key and at the same place you found the installation code which consists of ten lower case letters. Don't you have this stored?
    If not, please contact our sales office, be sure to have the serial number of your license available. They will be able to help you.
    Richard
  • weuns
    weuns over 15 years ago
    I purchased a version of Eagle Light (5.10.0) and received a single-user license. Everything is great, except when I was informed that a newer version (5.11.0) was available. I downloaded the new version, and the license key no longer works. In the Use License Key dialog I entered the key file and the word "commercial" (for the Installation Code, whatever that is) and the system now only lets me activate as "Freeware."
    Did I miss something, or do I have to purchase a new license for the new version?
  • Richard_H
    Richard_H over 15 years ago in reply to jgalak
    you wrote:
    I am trying to download the freeware version of Eagle (for Windows), but the download keeps failing.  I even tried grabbing a previous version, same thing.  The Mac version seems to download just fine...
    The links are working prefect. I just checked this. Could it be a matter of your firewall that it is not allowed o download exe files via ftp? please check the settings there.
    Richard
  • Richard_H
    Richard_H over 15 years ago in reply to mcerveny
    Hi Martin,
    you wrote:
    Did the CadSoft try to compile Eagle under OpenSolaris/SolarisExpress ?
    No we didn't. There are currently no plans to do so.
    Is there any tool to support advanced routing/testing in Eagle (routing the group of data/address/control wires for DDRx/PCIe/HDMI, routing of differential pairs, signal integrity tools ...) ?
    No there isn't. But there are some customer requests concerning differential pairs for example. Maybe we will have some more features in this subject with the next new EAGLE version. But currently we do not yet have fixed plans.
    Richard
  • jgalak
    jgalak over 15 years ago
  • mcerveny
    mcerveny over 15 years ago
    Hi.
    Thanks, Martin Cerveny
  • Richard_H
    Richard_H over 15 years ago in reply to Richard_H
    simply remove the folder you have installed EAGLE and delete the file named .eaglerc in your home folder.
    Regards from the Automaticon exhibition in Warsaw.
    Richard
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    EAGLE expects a 1 to 1 connection. One pin can be connected exactly with one pad. To have a proper definition you have to use three pins ion the schematic. You could for example use two short pins so that it look like one long pin and connect both to the net. Sorry there is curently no other solution available.
    Richard
    e14 Contributor over 15 years ago in reply to Richard_H
    Hi!
    I´m creating a D2PAK diode in the library editor, and since there are three pads but only two pins in the symbol, I need to connect one pin to two pads, but cant understand howto...any idea?
  • Richard_H
    quick solution is to draw a WIRE in layers 1 and 16 from pad to pad and NAME the wire the same as the signal name is. So will not get DRC errors.
    The proper solution would be to use three pins in the schematic and connect them all to the same net. So you would get airwires connecting all the pads in the board.
    Richard
