Forum ODB++ support in Eagle??
  • Replies 12 replies
  • Views 2661 views
  • eagle
  • odb++
IS there any way ODB++ files can be generated from eagle?
I tried by exporting to pulsonix first but with complex designs this gets messy.
    e14 Contributor over 16 years ago in reply to Richard_H
    Ok thanks for the fast reply,
    We have had several issues with assembly partners because they want to run valor checks on the boards and they cant run Valor checks on gerber files. When we use gencad sometimes the pads get rotated and then the optical instpection systems cant check the board because the pads are rotated in the files.
    All together we are verry happy using eagle but the incompatability  with other industry standards makes it difficult to use eagle from time to time. Ill hope you guys take this into account for future developments.
  • Richard_H
    Richard_H over 16 years ago
    I am sorry, EAGLE does not support ODB++ data export. You have to use Gerber/Extended Gerber instead.
    Currently I don't know about plans to support this....
    Richard
