Forum Reticon SAD1024 Delay Chip
  • Replies 39 replies
  • Answers 14 answers
  • Subscribers 191 subscribers
  • Views 10365 views
Andy Betts
Andy Betts over 8 years ago
Reaching out to the people on this web site.......
I'm after a SAD1024 delay chip, they were manufactured by Reticon and are now discontinued, and have been for around 30 years. I'm hoping someone here may have one lying around....... if so can you get back to me and I'll make you an offer to buy it off you.
As a heads up this is required for a planned pedal build, for the near future, but it all rests on being able to obtain this IC chip.
The data sheet is available to read here
http://www.pmerecords.com/Docs/Archer_SAD-1024_Tech_Data.pdf
  • Andy Betts
    Andy Betts over 7 years ago +6 verified
    I had a surprise in the last few weeks. I received an email from a gentleman named Niels who said he had 2 SAD1024 chips at work that they didn't need. Without any further ado he mailed them to me free…
    jw0752 over 8 years ago +4 suggested
    Hi Andy, I checked and I do not have this chip. Apparently it was sold for a while by Radio Shack under stock number 276-1761. There was some talk on the following link about using a MN3007 as a possible…
    michaelkellett over 8 years ago in reply to Andy Betts +2 suggested
    I thought about making a replica using modern bits, ADC , digital processing, DAC. Because of the way the chip works an exact replica is tricky: For an approximation: AD SSM2604, 24 bit 96kHz sample rate…
  • Andy Betts
    0 Andy Betts over 7 years ago in reply to Andy Betts
    I tried emailing, but it bounced back...... i put
    w5txr B (at) w5txr (dot) ty
  • Andy Betts
    Just found your website.... changed your address, hopefully it's right now
    Andy
  • Andy Betts
    0 Andy Betts over 7 years ago in reply to w5txrlabs
    Did you receive my email? I'm not 100% I got your address correct, even though it didn't bounce back
    Andy
  • mike5150
    0 mike5150 over 7 years ago
    Hi - I have an old mxr 117 flanger which I bought way back in the early 80’s when I was 15. Earlier this year it started making wierd noises and I took it to a guy who was recommended for repair. He’s run a full check on it and has told me that the reticon SAD1024  chip isn’t working and, unfortunately, they can’t be sourced in the uk. Aside from sounding great (in its prime) the pedal has a bit of sentimental value - as it’s my oldest piece of kit I still own from playing in bands in the 80’s. Any help finding a replacement chip is greatly appreciated. Cheers
  • Andy Betts
    0 Andy Betts over 7 years ago in reply to mike5150
    You just missed the boat.... I had a spare that i just the other week sold to a guy for £40
  • mike5150
    0 mike5150 over 7 years ago in reply to Andy Betts
    Shame - but at least they are still out there! I’ll keep my fingers crossed that someone has another spare. Cheers
  • vicwilliams
    0 vicwilliams over 6 years ago
    So theres allot of theory here. Can anyone recreate this chip?
  • _grep
    0 _grep over 6 years ago
    Hello all,
    I am looking for 2 (working) SAD1024 chips for a project. Let me know if you have some!
    All the best,
    Greg
    0 michaelkellett over 6 years ago in reply to vicwilliams
    I can - but I'd need to to see enthusiasm (huge amount) or business (less huge) image
    It won't be exactly the same but should be very close.
    You need a dual channel simultaneous 16 bit ADC and drivers, a small FPGA and a dual DAC and filter.
    It won't be the same size as the original chip and won't have the same distortion and noise profile -  the Reticon chip distortion increases with signal level but an ADC based system will have low distortion at high levels but quantising distortion at low levels.
    The  parts will cost about £30 (100 sets built) and more if a smaller number.
    If I sold such a thing at  £60 a pop - I'd need to sell more than 500 to make it commercially viable.
    I'd consider it as a community project if there were enough support.
  • madboy
    0 madboy over 6 years ago in reply to _grep
    I have 4 that I am looking to part with... a gift from my now ex father-in-law. They have never been used... Let me know if this is something I can help you with!
    Martin
