Forum Eagle Schematic
  • Replies 17 replies
  • Subscribers 177 subscribers
  • Views 1712 views
Eagle Schematic
Good morning or good evening everyone,
                                 I am having a slight problem with my schematic in the Cad-soft Eagle program. Recently I modify a schematic and added several changes, now I want to modify it again by adding some voltage source and some resistors, but whenever I use the net command  to connect the wires it is not working. I change the grid of the schematic to 0.1 bu the wires still won't connect.
Does anyone know what the problem is?  image
  • Richard_H
    0 Richard_H over 11 years ago in reply to Former Member
    Did you draw your nets on the 0.1inch grid as well?
    0 Former Member over 11 years ago in reply to Richard_H
    yes
  • Richard_H
    hmmm, it works here correctly.  The nets have to beginn exactly at the end of the pin where you can see the pin connection point displayed in layer 93.......
    -Richard
    Could you Resend me back the file do I can see the difference between them?
  • Richard_H
    okay.
    Thank you very very much. I had one wire that was not on the grid correctly so that prevent me from connecting the wires. Again thank you very much.
  • Richard_H
    Hi again,
    good to hear that it works now. image
    One final remark:  If there are more elements offg rid in the schematic you could run snap-on-grid-sch.ulp. This moves all objects into the given grid.....
    Have fun.
    Richard
