Rohm Semiconductor
  • Rohm Semiconductor
Rohm Semiconductor
Forum BP35C5 Wi-SUN module by ROHM semiconduction
Join Rohm Semiconductor to participate - click to join for free!
  • Subscribers 16 subscribers
  • Views 873 views
R.Manu
R.Manu over 2 years ago
Hey there!
I have been using BP35C5-T01 evaluation board along with BP359C evaluation board, for serial communication. The BP35C5-T01 evaluation board has two SMA connectors, to connect the antenna's. let me know if i can establish communication between modules without connecting antenna's. Also let me konw if i can establish communication between modules by connecting only one antenna.
Thanks...
Revanth
  • neilp
    neilp over 2 years ago +1
    Hi Revanth, Thank you for contacting ROHM Semiconductor on the Element14 community site, it's nice to hear from you. Please find our response below. When using the BP35C5-T01 evaluation board,…
  • neilp
    neilp over 2 years ago in reply to R.Manu +1
    Hi Revanth, Thank you for contacting ROHM. For BP35C5’s communication distance, please refer to the evaluation results described in “15. Communication distance” in the application manual. Attached in…
  • neilp
    Hi Revanth,
    When using the BP35C5-T01 evaluation board, please connect at least one antenna.  The antenna on the right side (ANT1) is enabled at first.
    The left side antenna (ANT2) is used when antenna diversity function is required.  Please also refer to the application notes for the BP35C5.  This can be found on the ROHM website or via the link below
    https://fscdn.rohm.com/en/products/databook/applinote/module/wireless/bp35c5_applicationmanual_an-e.pdf
    Thank you for your question.
    Kindest regards,
    ROHM Semiconductor
    www.rohm.com
  • R.Manu
    R.Manu over 2 years ago in reply to neilp
    Hey!
    What is the ideal distance for two modules(BP35C5-T01) to communicate, also at what is the maximum distance two module can communicate with each other.
    Thanks & Regards
    Revanth
  • neilp
    For BP35C5’s communication distance, please refer to the evaluation results described in “15. Communication distance” in the application manual.  Attached in the pdf
    Also note that the communicable distance and the connectable distance are different. (See “21. Distance of connectable and communicable” for details)
    Kindest regards
    Neil
