EAGLE User Support (English) Reference to uninitialize d object variable [5.11]
  • Replies 16 replies
  • Subscribers 178 subscribers
  • Views 1210 views
Yesterday I was fiddling around with an ulp to create a more complete FATF
file. Needless to say, it had 'some' typos... :roll:
When it finally started, I got (in the midst of processing) this message:
Reference to uninitialized object variable.
The line referred to is part of a loop that had already executed several
times without a problem, so I am at a loss here. To be more precise: the
processing of contact references on a net.
The design checks OK in both ERC and DRC, apart from some minor issues with
angles and such.
To check the data, I started another ulp (attached) on the same board to
find the culprit and got the same error message (at line 253), again while
processing contact references on that same net...
What causes this message, and more importantly, how do I solve it?
    Am 25.04.2016 um 09:39 schrieb Leo:
    angles and such.
    Do you get this message in all board files you tried or only in
    one board file?
    Maybe the problem is not in the ULP, but in the EAGLE file's data
    strucutre. In the older binary data it could happen that some
    objects were not deleted correctly or maybe some objects were pasted
    incorrectly....
    You could try to do a GROUP/CUT and PASTE into a new file and try to
    run the ULP again. Hope it helps....
    Richard Hammerl
    angles and such.
    one board file?
    incorrectly....
    Richard Hammerl
    angles and such.
    I know there used to be some bugs causing "null" objects on contacts.
    Line 253 says:
    printf("  CONTACTREF \"%s\"-\"%s\"\n",C.element.name,C.contact.name);
    If you add if(C.element && C.contact) do this, it might work.
    angles and such.
    Line 253 says:
    angles and such.
    Line 253 says:
    Thanks for the replies so far, it was both helpful and giving insight.
    No amount of cutting/pasting would resolve the issue, even a complete(?)
    removal of the offending net and connected parts did not help. Apparently
    there remained some sort of a stub...
    The check that Morten suggested circumvents the problem: no more crash.
    It generates however an 'empty' net reference that will most likely cause
    problems in the FATF output of the original ulp. But with the problem now
    identified, that is an easy fixable problem.
    I'd rather fix the source of the mayhem though, but the binary pcb format
    presents a major hurdle in this endeavour.
    Oh well, just another reason to upgrade I guess...
    The source of the problem is here: 5.11 image Time to upgrade?
    I made a script to remove null objects in 6.x, but cant remember if the
    clr/setgroup commands worked in 5.x.. Prob not. Anyway, I attach my script.
    You may find some very old threads written by me how to get rid of them
    them in 5.x... But my memory has faded.. I think it may involve some
    manual operations, like routing a dummy net to the contact and delete it
    again.
    again.
