Alpha Wire
  • Alpha Wire
Alpha Wire
Forum Need help with video wires!!! Please help!!!
Join Alpha Wire to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 1380 views
  • composite_video
  • questions
  • help!
  • video games
Hello my name is Brenton. I recently have started a project to make my ps2 portable. I got a car backup screen for the screen for the portable. I have been trying to solder the screen to the board. Only one problem, I don't know what I'm doing. I have the video cable cut and I have soldered it many times to the correct spot i have found  off a diagram. I just recently figured out I need ground. I have no idea which wire the video ground is. I doesn't even seem to exist. There are 2 video inputs, a white and a yellow. The only other wires are red and black, which are positive and negative for power. So my question is, which wire is ground? How do i find it? And will just soldering the yellow wire and the ground give video input? Thanks ahead of time. I appreciate your answer.
    shabaz over 10 years ago +1 suggested
    Did it work with normal cables before you hacked the wires? If you didn't test this, then you won't be sure it worked in the first place. If it did work with normal RCA cables connected between the screen…
  • mconners
    0 mconners over 10 years ago
    Can you give us a bit more information? What kind of car backup screen, what diagram are you following, etc...
    Mike
    0 shabaz over 10 years ago
    If it did work with normal RCA cables connected between the screen and PS2 then it should work if you use wires soldered to the same locations as the connectors. RCA connectors have two conductors - the outer conductor and an inner one.
    There is no yellow wire, just a coax cable with yellow jacket. Inside there is an outer braid and a centre conductor. The outer braid is the 'video ground' that you're referring to and the centre conductor is the video signal.
    Detailed photos will help.
  • mconners
    0 mconners over 10 years ago in reply to mconners
    Also, what type of video cable did you cut? Do you have any pics?
    Mike
