Altium CircuitStudio
  • Altium CircuitStudio
Blog CS issues
  • Author Author: photivs
  • Date Created: 6 Feb 2019 9:47 AM Date Created
  • Views 76791 views
CS issues
photivs
photivs
6 Feb 2019
Hi
I'm new user of CS (version 1.5.1) and have the following problems:
1. On PCB layout, when I draw a track, i want a hot key to change layer and to put automatically a VIA. I couldn't locate a such key (shortcut) within my CS installation.
2. If i press accidentally the "Windows Start" key  while i draw a track (it lies exactly next to the CTRL key on the keyboard and the CTRL is used very often), then CS gets stuck. The only way to escape is a forced termination of CS from Windows and lost of everything was designed so far.
3. I try to apply copper pour areas to create a GND plane on bottom layer, but except the GND net are also merged all other tracks on that layer.
Thanks for any help
  • ErikZ
    ErikZ over 4 years ago
    Regarding point 1: When you are routing and want to change the layer, hold SHIFT+CTRL and use your Mouse wheel to scroll through the signal layers
  • gustluiz
    gustluiz over 7 years ago
    Hi,
    "1. On PCB layout, when I draw a track, i want a hot key to change layer and to put automatically a VIA. I couldn't locate a such key (shortcut) within my CS installation."
              Try to use * key on numeric keypad.
