Altium CircuitStudio
  • Altium CircuitStudio
Blog Gerber Outline
  • Author Author: tonymodster
  • Date Created: 13 Dec 2022 3:47 AM Date Created
  • Views 3404 views
Gerber Outline
tonymodster
tonymodster
13 Dec 2022
Hello
What to select to generate a Gerber formatted outline file ?
I am using Circuit Studio.
Project->Generate Outputs
Thanks
  • tonymodster
    tonymodster over 3 years ago in reply to tyro02
    Thanks this helped
  • tyro02
    tyro02 over 3 years ago
    You are probably about to have resolved this issue.
    The layers that set the board outline vary from board factory.
    Some Chinese board factories instruct the board outline to be described on the GML (Milling Layer) or GKO (Keep Out Layer) layer.
    You should draw a board outline to Keep-Out Layer and check GKO on [Gerber setup]-[Layer] tab.
