Altium CircuitStudio
  • Altium CircuitStudio
Blog PCB Library connectors are getting flipped 180
  • Author Author: opeongo73
  • Date Created: 12 Aug 2017 11:18 PM Date Created
  • Views 923 views
opeongo73
opeongo73
12 Aug 2017
I am fixing up my custom connector library and have the connector(s) labelled from left to right as Pin 1 to Pin x.  For some reason while saving the library, CS deems it necessary to flip the connectors 180 degrees so that Pin 1 is now on the right. I can find no way to correct this or stop this from happening. Is this a bug or am I doing something wrong? This now makes the connectors on the pcb layout reversed from what they should be.
