Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Multiple output jobs
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1093 views
nfxsystems
nfxsystems over 7 years ago
Thanks to Generate Outputs produces more files than requested by ziomau10
Just like in AD, where I can have more flexible output file configurations, I can output 2 sch prints or 2 BOMs with different configurations.
in CS, change the project file like this:
[Configuration1]
Name=Default Configuration
ParameterCount=0
ConstraintFileCount=0
ReleaseItemId=
CurrentRevision=
Variant=[No Variations]
GenerateBOM=0
OutputJobsCount=2 //2 output jobs
DocumentReferenceClass1=DocumentReference
OutputJobFileName1=output1.OutJob //output job 1
DocumentReferenceClass2=DocumentReference
OutputJobFileName2=output2.OutJob //output job 2
then we can have 2 or more different outputs for the same type. for me, I always generate 2 BOM using different templates. I just enable the BOM generation in the 2nd outjob.
but the BOM output will replace the pdf file generated by 1st outjob. change the configuration in outjob 2:
OutputType12=BOM_PartType
OutputName12=BOM_PartType
OutputCategory12=Report
OutputDocumentPath12=
OutputVariantName12=
OutputEnabled12=1
OutputEnabled12_OutputMedium1=1
OutputEnabled12_OutputMedium2=0 //disable BOM output pdf print
OutputEnabled12_OutputMedium3=1
OutputEnabled12_OutputMedium4=0
it's more convenient to create a template project folder with these files.
hope this will help ^_^
  • ziomau10
    ziomau10 over 7 years ago
    It souds useful, but I think you have to tweak the project file by hand, don't you?
    Also I think, there is no way to manage the second OutJob file via user interface, and also that must be changed by hand.
    As I said, sounds useful, but complex
    What do you think?
    Thanks.
    Mau.
  • nfxsystems
    nfxsystems over 7 years ago in reply to ziomau10
    yes you do need to edit the project file.
    but for the outjob file, it is updated anytime you change it in the GUI. you can finish one file and save it as outjob1 then edit another one as oubjob2.
