Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to dis-polygon pour on PCB
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 1891 views
mike.wang@laipac.com
mike.wang@laipac.com over 7 years ago
How to dis-polygon pour on PCB, so I can do the route work.
Thanks!
  • frog
    frog over 7 years ago
    Could you explain a little more about what you want to achieve?  I'm guessing you have a polygon and you want to route a track through it?
  • adamwebber
    adamwebber over 7 years ago
    To un-pour polygons:
    1-Right-click your polygon.  (Your active layer must be the polygon layer)
    2-Hover over 'Polygon Actions'
    3-Select 'Set All to Unpoured' or 'Set Selected to Unpoured'
    You can repour the polygon the same way as above but it's much easier to go to the Polygon pour drop-down menu in the Home tab.
  • mike.wang@laipac.com
    Thanks James, it works!
