Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to specify solder mask and silk screen so I don't throw design rule warnings?
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 923 views
  • silk
  • drc
  • soldermask
somedude
somedude over 7 years ago
typically, when I have PCBs made, I don't mind if silk screen overlaps the soldermask opening or the copper, because I request no silk over copper or soldermask openings. however, I'm using circuitstudio now, and I want to clear out all of my design rule warnings/errors. is there a way to specify in circuitstudio to automatically trim the silk screen and to ignore overlap violations?
  • clem57
    clem57 over 7 years ago
    Oddly or not, this can be done in AD https://www.altium.com/documentation/altium-designer/pcb-dlg-silktosoldermaskclearance-framesilk-to-solder-mask-clearanc…
  • somedude
    somedude over 7 years ago in reply to clem57
    I believe that will work to get rid of the DRC in CS also. should I just do that and let the manufacturer clip the silk? I was hoping I could get my gerber outputs to be pre-clipped somehow. I always like to have everything in the gerber to prevent issues changing board houses.
