Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Supplier Links Broken
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 606 views
zekeymonkey
zekeymonkey over 6 years ago
I just reinstall Circuit Studio 1.5.2 build 30 and the supplier links no longer work. There are now no suppliers available. Does anyone know how to fix this problem?
  • tarribred61
    tarribred61 over 6 years ago
    For what it is worth, I notice that if I click on the Verified column heading, my views cycle through some of the suppliers. I'm not sure what it is doing but I can get my view to look like you are showing.  Also, changing the width of the column is behaving similarly.
    I don't understand what it is doing so maybe this is a bug?
    Here is the link for the Altium Designer description of this feature.
    https://www.altium.com/documentation/altium-designer/integratedlibrary-dlg-intlibprefsform-suppliersdata-management-supp…
    This describes what it is intended to do.  It does mention that you may need to enable the supplier extensions.
  • zekeymonkey
    zekeymonkey over 6 years ago in reply to tarribred61
    Uninstalling the Altium parts provider extension and then re-installing it seems to have fixed the problem.
