Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Annotate messes up multi-part component
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2438 views
  • multi-part
dbemmann
dbemmann over 6 years ago
I have defined a component for a 74HC08 Quad AND gate. My component consists of 5 parts:
Part A:  AND gate 1 (inputs A1, B1, output Y1)
Part B:  AND gate 2 (inputs A2, B2, output Y2)
Part C:  AND gate 3 (inputs A3, B3, output Y3)
Part D:  AND gate 4 (inputs A4, B4, output Y4)
Part E:  Ports GND, VCC
When I use the function "Annotate quietly", it messes up the circuit by exchanging Part A with Part E (which are obviously not interchangable). How can I fix this?
  • mc6800
    mc6800 over 6 years ago +1
    The other way is to configure part swapping in the library. Open the schematic library, and type "swap" in the search box. Click on "Tools->Configure Swapping". This presents a dialog box with all multi…
  • tarribred61
    tarribred61 over 6 years ago
    Have you tried locking the parts.  You can do this in the library or at the schematic level.  If you are gate swapping for placement purposes you might want to control this.
  • dbemmann
    dbemmann over 6 years ago in reply to tarribred61
    So I need to set this to locked in the library, for all parts of that component?
  • tarribred61
    tarribred61 over 6 years ago in reply to dbemmann
    If you set it in the library then you also need to update the schematic instances from the library.  Or you can lock it on the schematic and leave the library alone.
  • mc6800
    The other way is to configure part swapping in the library. Open the schematic library, and type "swap" in the search box. Click on "Tools->Configure Swapping". This presents a dialog box with all multi-part components. Choose one, and select "configure conmponent". On the "part swapping" tab, assign  a number to any parts that can be swapped, and a different number for other parts. Also use the sequence id to identify which pins are funtioanly identical (eg AB for inputs, Y for outputs). Save the library, and update the schematic from the library component to get the changes.
    You can also right-click a component in a schematic, and choose Part Actions -> Configure Pin Swapping to change things.
  • dbemmann
    dbemmann over 6 years ago in reply to mc6800
    Great. I think this is the way to go.
