Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Is there an easier way to add a 3D rendering to a component rather than have to recreate the component in a library?
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 878 views
sshaferdlm
sshaferdlm over 6 years ago
I have been trying to add a 3D step file to an already existing part. From digging through all the help files and videos it appears this can only be done when creating a new part.
Is there another way that I'm missing?
  • tarribred61
    tarribred61 over 6 years ago +1
    Hey, Yes you can add a 3D body to a component that already exists in a library. You can modify a 3D body that is already there also. If you have been trying this already, please add some detail about why…
  • sshaferdlm
    sshaferdlm over 6 years ago +1
    Hi Thomas, I was able to finally add a step file to a part. Wasn't easy to figure out, that you can right click on the part in the "Description" box of the Library tab and edit footprint. then click on…
  • tarribred61
    Hey,
    If you have been trying this already, please add some detail about why it might not be working.
  • sshaferdlm
    Hi Thomas,
         I was able to finally add a step file to a part. Wasn't easy to figure out, that you can right click on the part in the "Description" box of the Library tab and edit footprint. then click on 3D Body in place tab.
    However this does not appear to be an option for all components
  • tarribred61
    tarribred61 over 6 years ago in reply to sshaferdlm
    I find it is easier to manipulate and edit the parts by actually opening the schlib or the pcblib instead of through the libraries view pane.  This is under the file > Open Document and then browse to the file.
    But yeah you can do it that way too.
    For what it is worth and if you didn't know, you can add and manipulate 3D bodies on the PCB without being in a component.  There is no menu icon for it but if you are in the PCB and use the search/command window and type in Place... you get some commands include Place 3D body.  It becomes a free model in the design.
  • sshaferdlm
    Nice Works good.
    Steve
