Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Unable to move a reference designator
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 980 views
jmarkwolf
jmarkwolf over 5 years ago
More questions regarding editing after an Eagle import into CS v1.52.
There are numerous instances of the designator being "hard attached" to it's respective part after the import. See pic below.
In this instance, I can select and move the "100 kOhm" at will, but am unable to move the R165 nor R166 even though the dashed green window appears around the designator.
Any advise?
  • tarribred61
    tarribred61 over 5 years ago
    Maybe it is off grid?  Try holding the CTRL key while you use the mouse to select it.
  • jmarkwolf
    jmarkwolf over 5 years ago in reply to tarribred61
    Right you are again Thomas, thanks.
