Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Interactive routing visibility problems
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 716 views
chendeflorian
chendeflorian over 5 years ago
I am sorry if this has been discussed here before, I was not able to find it.
While I am doing interactive routing I have some visibility problems. When I choose a net to work on, all other nets/vias disappears from my view, I cannot see them. I can only guess where they are after the shadows they make over the grids. It is very difficult to work this way.
How can I change this? I attached 2 pictures, one with normal view, other with interactive routing started.
  • adamwebber
    adamwebber over 5 years ago
    You've probably got your Dim Level set too low.  In the VIEW tab, there are a couple of slider bars at the right.  Change your Dim Level to about 60%.  This will keep your selected net at 100% and everything else will be at 60% opacity.  I'm guessing yours is at 0%.  Set the value at whatever suits your needs.
  • chendeflorian
    chendeflorian over 5 years ago in reply to adamwebber
    Thanks, it worked. I didn't think to look in tabs, I only searched in settings and preferences.
