Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum PCB Spiral Antenna Design
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 4011 views
  • nfc
  • antenna design
  • circuitstudio
  • antenna
  • pcb design
yarshun9
yarshun9 over 5 years ago
I'm planning to design a PCB Spiral Antenna in CircuitStudio. How do I go about creating/drawing this part while ensuring the rate of increase of spiral diameter is consistent? image
    dougw over 5 years ago +1
    I don't know if it is a true spiral but if you take a bunch of concentric circles, where the spacings are all the same, then cut the whole group in half and shift one half over one space, then you can…
  • javagoza
    javagoza over 5 years ago +1
    Don't know anything about CircuitStudio. If you can import png I think you could use Inkskape to draw the spiral. I think it is an Archimedean spiral Create the spiral adjust stroke width and export png…
  • nhee
    nhee over 5 years ago
    The only thing that comes to mind is generating the spiral in mechanical CAD as an option of helix generation.  Bring it into CircuitStudio as a DXF file.
    I don't know if it is a true spiral but if you take a bunch of concentric circles, where the spacings are all the same, then cut the whole group in half and shift one half over one space, then you can join semicircles that will have consistent spacing and a slightly lopsided "spiral" shape. See the blue spiral below:
  • javagoza
    Create the spiral adjust stroke width and export png.
    Spirals (free.fr)
    A divergence of one gives a spiral where the distance between successive turns remains uniform (an Archimedes' spiral)
