Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Altium designer error: port has only 1 pin
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1348 views
  • altium designer
  • port;
  • error?
Hello Everyone
I am designing a multi-sheet schematics for a project. I have started with altium since last 10 days, hence there are few things that are not clear to me. I am using "port" to connect a pin from sheet 2 that needs to be connected on sheet 3. So I named the port as SPI_DQ on the pin on sheet 2 as well as the same "net label". I am doing exactly the same thing on the respective pin on sheet 3. As I read the documentation, it says making the "net labels and ports as global" it will directly connect to the nets and ports assigned with the same names on different sheets.
I tried changing the options in Project Options but I am facing the same error "Net SPI_DQ has only 1 pin"
Am I missing something? What If use Off sheet connector instead?
Thank You.
Best Regards
