Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio - "Parameter Import Options"
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 705 views
  • parameter import options
  • supplier links
When I click on Supplier Links and assign a part from a  supplier to a schematic symbol, it will only import the "Supplier 1" and "Supplier Part Number 1" parameters.  Why won't it import other parameters that are specified in the "Parameter Import Options" section located in the Data Management -> Suppliers preferences?
Thanks.
Mike
    maybe it is due to limitations.
    is the supplier 1 "farnell"
    in the full altium you have rs/farnell/digikey/tme .
    Rune
  • e14softwareteam
    0 e14softwareteam over 10 years ago
    Hi Michael,
    Within CircuitStudio there is a section called Extensions and updates. In this section the customer has the option select the manufacturers they would like to see pricing/stock info when they hover over a part on the schematic.
    Under the Supplier Section the customer has the option to select “All Suppliers” .
    From our experience- the initial set up only includes Farnell as the selected default supplier, but the customer can still go to the Configuration tab under Extensions and Updates to select All Suppliers or the preferred suppliers.
    I hope that helps!
    Tony
