Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Bug Update
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 661 views
Bug Update
harvie256
harvie256 over 10 years ago
In September I asked for feedback at pcbsoftware@element14.com on two bugs I reported:
https://www.element14.com/community/thread/56534/l/bug-report-pcblib-inspector-unable-to-change-multi-layer-pads-to-single-layer
https://www.element14.com/community/thread/56533/l/bug-report-non-simple-pads-not-saving-correctly
The response I got was:
"I will of course ask the questions for you and relay the information as soon as I get it."
Is there any update on these bugs and if fixes have made it into the V1.3 that's keeps being advertised.
Regards
  • harvie256
    harvie256 over 10 years ago in reply to e14softwareteam +1
    Thanks for the reply. That's a completely usable work around for changing the pad to single layer. Sounds like a fix isn't going to make it into CS or AD in the near future, so perhaps documenting this…
  • e14softwareteam
    0 e14softwareteam over 10 years ago
    I have resubmitted these to the developers and will let you know the status as soon as they respond.
    Tony
  • e14softwareteam
    I am sorry that you did not get responses to these bugs previously.  However, here are the responses I received from the developers:
    Multilayer: Thank you for reporting this bug. The software should set the hole size to zero instead of forcing back to Multilayer, however it currently is designed only to react to the non-zero hole size and set the pad to multilayer. This behavior also exists in Altium Designer and any changes need to be addressed in both places so would need some priority to be addressed.  The best way to use the PCB Inspector for this operation is to first set the hole size to 0 and then change the layer from Multilayer to another layer.
    Non-Simple Pads: Thank you for reporting this issue. This is logged as a bug for consideration in CircuitStudio 2.0 but unfortunately won't make it into version 1.3.
    Let us know if we can be of further assistance.
    Tony
  • harvie256
    0 harvie256 over 10 years ago in reply to e14softwareteam
    That's a completely usable work around for changing the pad to single layer.  Sounds like a fix isn't going to make it into CS or AD in the near future, so perhaps documenting this behaviour and the work around in the product manual would be an appropriate short term solution.
    This is the first I've heard of CS 2.0.  Do you have a road map of expected release dates (roughly of course)?
    Thanks for your help.
  • pwenzel
    0 pwenzel over 10 years ago in reply to harvie256
    harvie256,
    The roadmap is ever evolving (and always subject to change!) but v2.0 is targeted for around 2Q17 with a tentative point release, beyond v1.3, scheduled sometime between now and then.
    Pete
